Question about LG WM-2277HW Front Load Washer
Rubber seal removal
How do I remove the rubber seal without breaking it ?
  • RamonC Feb 20, 2008
    Thanks Buddy ! Your The BEST !!!!!
    New Friend:
  • 60 Answers
There is a spring at the bottom center of the door gasket. Stretch that out and a wire will come off from around the gasket you can then pull the gasket off and reach in. Be sure you get the gasket back on all the way and the wire right or it will leak. Good luck.
Posted on Feb 16, 2008
How do you replace a oil pan on a 02 kia sportage?
Jack up car put on stands remove exhaust if it crosses under sump remove all the screws or nut bang side of sump with a rubber hammer to break seal,clean off old sealer.
Aug 15, 2014 | 2002 Kia Sportage
How to remove rubber seals from inside moen 1225 faucet body
Make a cutter from the old cartridge. Cut some slots in the base that normally sits on the seal. Use a hacksaw or grinderette.
Clean up with a file to prevent damage to the sealing face. Insert the old cartridge back and give it a few gentle turns with minimum pressure. Remove 'cutter' and flush out debris.
Oct 26, 2017 | Home
1986 suburban cargo door window replacement
Since you have a the original rubber seal from your broken glass, cut the seal from the outer edge of the replacement glass and just push it out of the remainder of the rubber. With the original rubber still in the opening on the one your putting it in, lay a strong string from top corner, inside the space where the glass goes, and across the bottom. Push the glass into the seal on opposite side from the string side as much in as possible and begin to pull the string straight out while holding the glass in and this will pull the rest of the outer rubber lip to the outside of the glass and your done. Just a little trick I learned in my youth that I've used many times.
Aug 29, 2017 | 2003 Renault Renault Scenic 1.6
How to remove injector once fuel rail is free. have fuel rail up but cannot get injector off it...
The injector just pulls out, twist it around to break the O rings seal and pull while you twist it. The Injectors rubber O ring seal gets vulcanized to the metal rail after many years, and can be difficult to remove.
Here is a picture of the ionjector and the sealing O rings at both ends.
Mar 22, 2011 | 1998 Buick Century
How do you remove the piston from a front master cylinder on a Kawasaki KZ1000 B3 1979 LTD
first you must remove the lever from the master cylinder, then you will see a rubber seal this must be removed, it is not always possible to remove this seal without damage so i would suggest u find a replacment, the outer of the seal can corrode to the master cylinder, once you have removed this you will find a circlip which holds in the piston, remove this keeping a slight pressure on the piston as it is spring loaded, remove carefully so u can ensure correct reassembly of parts, in some occasions the circlip is located on top of the rubber seal.
Oct 31, 2010 | kawasaki Z1 Motorcycles
Pool sweep pump stuck and will not turn.Binding on impeller to rubber seal.How to disassemble remove impeller and seal.
Sounds like maybe your motor bearing are going bad, or have already seized up. When you say "rubber seal" are you referring to the rubber portion of the shaft seal? Either way, to remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. If the bearings are seized up then you'll have to replace the motor, or have it rebuilt.
Sep 18, 2010 | Pentair Letro Booster Pump IMPELLER LA02L
Can you slide the transmissin away and replace seal
It would be nice to know what year & model.
But still not likely.
To replace the front seal If it is an AUTOMATIC, you must remove a lot of parts.
For front wheel drive the first thing are the wheels. Then drop the lower ball joints,break loose the struts from the tie-rods. In some cases lower control arms, sway bars, stabilizers,exhaust systems
The drive shaft(rear wheel drive) or drive-axles (front wheel drive),
transmission mount
cross-member (rear wheel)
shift rods or cable
hydraulic lines (if automatic)
inspection/access cover at bottom-rear of engine,electrical sensors(if applicable). Then the Bell housing bolts as well as torque converter bolts.
And THEN, because the torque converter holds the majority of your transmission fluid the transmission must be removed with the torque converter attached.Moved far enough away that the converter can be removed safely without spilling the fluid everywhere and where the removal & replacement of the seal can take place where as not to damage it during installation.
Some seals if aren't put it perfectly straight will kink the rubber and jeopardize the whole job.
And the worst thing that can happen after that big job is to have a leak. It must be done right without taking short cuts.
Its a $10.00 part but $300 -$1000 OR MORE to put it in.
Sep 18, 2010 | Plymouth Breeze Cars & Trucks
Hoover Quattro Whisper 1400 washing machine AE 240 I would like to clean the filter as scum builds inside the rubber seal on the door Cant find the filter, no obvious opening
On the front bottom of the machine there is a plastic 'kick plate' that clips/pushes on. Remove this plate and you will see the filter with a cover secured by a star/phillips screw. Loosen screw and twist this cover off to gain acess. Don't do what i've just done and twist without removing this screw as it breaks it:-(
anyone who knows where i can get a filter cover please post back!
Aug 12, 2010 | Hoover Washing Machines
1991 dodge dynasty rear window removal
I have never been able to remove sealed in glass without breaking it. But in theory if you can get a guitar string through the sealant and pull it through like a cable saw you might get it out. I've tried 15 times, and have 15 broken windshields to show for it. good luck
Jan 10, 2009 | 1991 Dodge Dynasty
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
720 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
