Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Very hot compresser upside down fidge
Fisher and paykel active smart upside down fridge.
freezer section cold., fridge section not
compressor at rear of fridge very hotto touch
don't know if little fan from frezzer to fridge section is working
  • 22chtac Feb 24, 2008
    There is no outside coil or fan
  • Anonymous Mar 23, 2008
    yeh mines same hot compressor fisher & paykel model N249T only my one is right side up fan still working ln freezer compartment there does not seems to be any coil coming from the comp only three cooper tubeing going up into the inside of the fridge part,but that seems to be sealed of ! ! !
    dumbfounded
    Sergeant:
  • 288 Answers
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Posted on Feb 16, 2008
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Our upside down fridge/freezer started to beep. Upon opening the fridge the thermostat lights on the back was flashing red then green then red again anyone help?
This is a connection issue between one of the temperature sensors and the electronics, the plugs on the sensors need to be removed and cleaned with contact cleaner and you need to make sure that the contact are pushing firmly against the circuit boards, there are 2 control units, one behind the fridge beside the compressor and one in the back of the fridge which you get to by simply pulling the middle rear panel out after removing the shelves, just be careful as you can damage the plastic.
Mar 05, 2012 | Fisher and Paykel Active Smart E522B...
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Freezer nice but fridge is very warm
When fridge or freezer compressor is running but contents are not cold, feel the black radiator with the hand. Basically if the radiator is cold there is no gas or a bad blockage or a leak.( Radiator must be nice and warm on one 1/3 of its length.).
Dec 13, 2010 | Fisher and Paykel Active Smart E522B...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Leaking water inside fridge
With mine I turned it off for 24 hours until totally defrosted. Checked behind the panel of the freezer and removed one stubborn piece of ice. When I restared the fridge it was all good. I have this problem when we have had a lot of humid weather.
Feb 22, 2009 | Fisher and Paykel Active Smart E522B...
F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Nov 06, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher Paykel Active Smart fridge turned into storage unit by power surge
I would unplugg the machine for 5 minutes, plug back in again and close the freezer door, open fridge door and press the mode button
Jun 22, 2008 | Fisher and Paykel Active Smart® E522BR...
Cold fridge but not freezer
try DEFROSTING the fridge and restart it after COMPLETELY defrosting it.
May 05, 2008 | Fisher and Paykel Active Smart E522B...
Fisher Paykel fridge stopped working
youre meant to if moved, let it sit for atleast an hour before turning on because moving it disrupts the gas inside. Did you do that?
Nov 28, 2007 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
373 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
