Question about Brother FAX-575 Plain Paper Thermal
Receive faxes Hi..I have a tad downstairs in my home and Fax machine in an upstairs room..I have no problem in sending Faxes but am unsure of hookup to receive them..Help
    New Friend:
  • 120 Answers
In the receive mode choose tad. The fax will then distinguish between a fax and a call.
Posted on Feb 16, 2008
I want to buy the Canon ImageCLASS MF4350d all in one printer. My main concern is receiving faxes. I have a cordless phone with built in answering machine installed in a phone jack downstairs.. the...
No you cannot do it that way. The TAM (Telephone Answering machine) must use the tad port in the machine otherwise the fax will not detect an incoming ring and the fax switch will not function. Your best option would be to put the master phone with the fax and take one of the wireless phones and put that in its place. the cordless does not have to be in the houses master socket. It will work happily on any extension in the house.
Aug 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
I have a Brother Fax 2820 at home. It is connected to a TAD. I want an external fax machine to send and bypass the voicemail greeting and print the fax. I thought I set the machine to TAD. Any other...
try this paul. hook your phone line from your wall jack to your "line" jack on your fax. then run another phone line from your "external" jack on your fax to your "line" jack on your TAD. now, make sure your fax machine is still set to TAD. here is whats important...set your TAD to 4 rings or less. 2 is the recommened setting. also very important...when you record your outgoing message on your TAD, make sure you leave about 5 seconds of silence before you start recording your message. the reason for this is the fax machine needs to "hear" the CNG tones that originate from the sending fax so that it knows its a fax and then can take over the call. if it doesn't hear those tones because of noise (voices, etc), it will let call go to TAD. you can try to set your TAD to 4 rings, but that doesn't leave much time for fax to "hear" these tones. if you set to 4 and don't get all your faxes, try lowering the setting to 2 or 3 rings.
good luck and hth,
razors
Mar 02, 2011 | Brother IntelliFax-2820 Laser Fax
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Problem receiving faxes
your fax is in tad mode (telephone answering device) press the receive button (next to the start button) until you see fax only on the display this will correct the problem.if you have faxes in memory press the report key for reports, then opt.1 for help list
look for print fax
Jul 15, 2008 | Brother IntelliFAX 2800 Laser Fax
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
Cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
Phone hookup
First only plug the line in the LINE socket otherwise it wont receive.
Manual receive will probably be the best as conflict may occur with the answering machine and the fax. You will either not receive faxes or messages. Its a bit of a pain as you will have to be home to receive faxes. eg pick up the handset and press start.
Its the easiest. Unless you want to fiddle with both machines settings to use the fax/telephone mode.
Mar 13, 2008 | Brother IntelliFAX 2800 Laser Fax
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother FAX-575 Plain Paper Thermal Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
