Question about Radio Communications
My galaxy 959 cb radio wil not put out any transmit
My galaxy 959 cb radio will not put out any transmit
  • 1 more comment
  • Anonymous Feb 16, 2008
    i changed microphones, i changed coax, i checked the output, i think maybe it needs a output final.
  • paul prosise Feb 23, 2008
    brand new radio and having the same problem as mo mo 2008. i thought galaxys were supposed to be good radios.if im having problems right out of the box,they aren't very good.tx light lights up when ptt button is pressed,swr shows at a 1
  • Anonymous Nov 17, 2008
    959 does not trans. stopped all at once mic good had finals checked not the problem light changes to red keying up meter does not move took it to a cb tech he said he did not know what would cause this need some help thanks joker
    Brigadier General:
  • 6,966 Answers
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
Need wiring help for Galaxy 959 Cb Mic
1) shield / ground 2) yellow/ audio 3) red / transmit 4) white / receive
Mar 17, 2013 | Galaxy Radios 959 40 Channel Am/ssb Radio
Tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
on Oct 15, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx55hp stuck on channel 10.695
radio has a 3 yr warranty .send it back to galaxy
Nov 15, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
GALAXY 959 CAN TRANSMIT BUT NO RECEIVE
try the external speaker /if that is not working you may need put in a new receiving chip it is on the right side has 10 pins.
Jan 03, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Radio Communications Logo
962 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
