Question about Maytag MAH6700AWW Neptune Front-Load Washer
Circuit board machiene was doing fine and just stopped, have checked it is getting power to the board via white wire from noise filter. power ends there door is closed and will not open no lights or anything the washer is mah6700aww
    Genius:
  • 1,665 Answers
If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit
Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed
If the washer still doesn't work, may circuit board/timer be defective.Have an authorized tech to figure out and if it is posible to repair. For replacement as complete part see link below:
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
At the link next you can find other usefull info about your machine.
http://www.shophta.net/_CGI/MODEL?KEY=MAY:MAH6700AWW
use & care:
http://specs.retaildeck.com/CACHE/FILE12376.PDF
Posted on Feb 16, 2008
    President:
  • 1,314 Answers
First off you can remove the dispensor drawer and under it there is a yellow pull tab that will open the door which cycle was it in when it died
  • robert samples Feb 16, 2008
    the only thing i can see that will kill it all is the door switch check for power comming there and out
    if you had power on a white wire white is neutral and the door lock switch isnt closing check for power on the push to start switch grey wire with the door closed let me know what you have there
  • 72 Answers
Is one of the fuses or reisitors blown? use an omi meter and check the reisitors see if there actualy resisting current if not then you will see what is burned on is out.
    Novelist:
  • 123 Answers
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 16, 2008
    contact yours tecnician
    Good Luck
    here is the link of your customer support
    http://personafile.com/Maytag-Front-Load...
    Good Luck
    Good luck
No power to unit replaced thermostat , door switches, diode on capacitor but not the two fuses continuity goes to 0
There are 2 thermostats or "thermal fuses" in it that would cause no power. One is on the magnetron, the other is above the microwave cavity near the middle. Have you checked/replaced both? You should have 120 volts between the white wire on the main relay on the circuit board & the black wire in the smaller connector on the board. If you do, bad board, if not, something before the board (fuses, thermostats, noise filter board, etc). Door switches, diode, capacitor would not cause no power to unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Jun 03, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
Magic chef mco165uw has no power
I didn't know they had noise filters! :)
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 28, 2013 | Magic Chef 1.6 cu. ft. Over-the-Range...
I have a 2002 GMC 1500hd 4x4 6.0 gas engine. Have no break lights. Tail lights and turn signals work fine. Replaced fuses and stop light switch and still have no break lights
GM had a lot of problems with the circuit boards that house the rear lights. My suggestion is to use a test light clip one end to the trucks body parts then remove brake light switch the orange wire should light the bulb on test light this is the power wire, the white wire is the stop light circuit with switch out this also should be lite up. Drop down turn signal switch connector the brake lamp wire goes up the turn signal switch and comes back down the yellow and green wires no power there it is a bad turn signal switch. If Ok Now remove one tail lamp assembly unplug harness and test for power if still have no power trace wiring back to fire wall and check at bulkhead connector. IF ok then circuit board is bad.
Nov 11, 2013 | Cars & Trucks
Parex beta 90 ss rangehood stopped working Lights on switches work but not the fans or lights
Unfortunately didnt do anything about this for years. Managed to take off the white box behind the front panel swithes. Opened this up and "hey presto" the circuit board is faulty. Wouldnt it be nice if De Longhi sent out another one free of charge as this is obviously faulty, looking at some of the same complaints that have been posted. Imagine all the people that dont use computer or internet. I soldered wire between the points and it worked straight away.
Jun 10, 2011 | Microwave Ovens
I can't find where the fuse is located on a phaff 1069. The manual I have is for a 1067, 1069 and 1047. The picture showing where the fuse is at is NOT in the same location.( Next to the power cord...
There is a fuse located on the circuit board that is in the main motor. You need to remove the top cover, front cover, and stitch buttons, cover. You will then see the main motor. Once you have it out, you need to be careful as you disassemble it, as it has 2 very fine copper wires that connect the circuit board to the field windings. Look for the fuse housing that is on the circuit board. If the fuse checks out good, check the motor carbons. They may be worn down far enough to not make contact with the armiture.
May 02, 2011 | PfaFF Tiptronic 2040
Dyson dc 15 brush roll not spinning. motor is good, upper switch is good.
Open the right side of the vacuum with a hex head screw driver. There are 4 screws. Inside you will find a circuit board.
1. Make sure the varistor (S20K150) is not blown, these models seem to have an issue with this. It is a flat blue "quarter" looking component near the top edge of the circuit board.
2. At the bottom of the circuit board are two white wires connected via push on connectors. Remove these from the circuit board by sliding them away from the circuit board. Power on the vacuum and engage the drive button. If the lower motor still does not engage check step 3.
3. A blue and yellow wire runs off the bottom end of the circuit board. These are the wires powering the lower motor. Check continuity with a multimeter and make sure they are not broken. I have seen where these wires will break as they run through the housing of the vacuum. If they are broken, replace them with any wire of the same gauge.
Dec 15, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
I have an LG WM2277HW washing machine. My wife went in this morning to do some laundry and the thing is completely dead. No lights or signs of life. I checked the house circuit and the power to the...
Make sure the noise filter connectors are clean and connected properly. Get yourself a multimeter and check the voltage both on the load side and line side of the noise filter. It should read the same at 120VAC. The noise filter is the board before the main board. Replace it if the voltages on its load and line side are not the same.
The main board is not serviceable and must be replaced if faulty. It has a fuse and if it is blown, the main board is probably faulty. Look at the two brown capacitors on the top left of the main board. Next to it is a heat sink and to its right is a white "fuse-like" component with silver ends. That is the main board fuse. If it is blown, disconnect all the connectors from the main board except the one connecting it to the noise filter. Jump a single thin strand of wire in place of the fuse and apply power to the machine. Check if the power LED indicator on the main board lights up. If it does not, the main board is dead, replace it.
Please do not hesitate to update me about your findings above for further guidance if necessary.
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | Dishwashers
Continuous alarm
I posted this under "Ben's" problem as well, but I had the exact same problem. I know which black and white wires you're talking about. I don't know what causes this, but getting new parts did fix it. The black box that all those wires go into on the right side is called the control module. I thought about replacing just this, but I saw several blogs of people who did this and the beeping continued. So, I got a new touchpad as well-and voila, the dishwasher is working again.
May 25, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
142 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
