My Yamaha r1 2008 engine overheating I changed the fan, using coolant, changing the bearing but still same
SOURCE: changing yzf r1 frame
you wont get one, you just have to figure it out as you go. start by stripping all your bodywork off and removing the engine, then the front forks rear wheel and wiring harness. then replace it all on your new frame. keep your work area clean and tidy, mark all electrical connections you have to undo with tape and write on it where they re-connect to.
good luck
SOURCE: My Yamaha FZR 250 ran out of oil and coolant and
Very likely yes. If it won't turn over at all you will probably need a complete rebuild. If it turns over but won't run I would check the compression before I rebuilt it.
SOURCE: ineed a wiring diagram for 2008 yamaha yzf r1
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
SOURCE: How can I find my Yamaha YZF R1 2005 paint colour code & where can I purchase?
The colour code should be on the frame, usually under the seat.To find a supplier, just use a search engine and find a distributor locally. Or order it online.
Did you change the engine oil as well?
