Question about Cherokee (REF) AM/FM Stereo with CD Player and Hands-Free Capability
1997 Grand Cherokee - Car won't start
After changing the alternator, the car turns over, but will not start. The low fuel light is on and the Overdrive light stays on. And the Alarm will not turn on. Can't find any blown fuses. Suggestions? thanks.
  • 2,039 Answers
Lot of time the idle air control closed completly try to starts the truck and pressing the gas pedal bit if it start you gonna have to press the gas pedal to keep it running and it should ajust itself thanks for using fixya pierre
Posted on Feb 16, 2008
After I change the fuel pump wen I try to sart my car I hearthe pump keep runig and the car don`t start my car is 1997 Jeep Cherokee sport 4.0 6 cil.
Ok calm down the fuel pump works find someone to computer scan for codes. check for fuel pressure at engine an spark
Nov 21, 2015 | 1997 Jeep Grand Cherokee
Car didn't start
I have the same issue with my 1997 jeep grand cherokee ,and i am a mechanic ,and still do not have a clue
Nov 04, 2012 | 1994 Jeep Grand Cherokee
Jeep cut off while driving, will not start and battery dead. It start shaking and when I try to restart I was smelling fuel.
alternator went causing you to run out the battery gas smell might unburnt fuel in the exhaust.charge up battery get it started and check charging system.ps check the large fuses under the hood located on the passenger fender.one belongs to the alternator.
Sep 06, 2011 | 1997 Jeep Grand Cherokee
1998 Jeep grand cherokee Laredo turning over but won't start. It sounds like it wants to start but just won't power into it. We changed spark plugs w/in last year, brand new battery, the alternator...
When it sounds like it wants to start but won't, it is almost always a fuel problem. When you first turn on the ignition key (radio off, in a quiet setting) do you hear a faint 'hum' from the rear of the car? If so, your fuel pump is probably alright, so the next check it to remove the small, light green plastic cap (it might be black, about the size of a tire valve cap) on the top of the engine-it is part of the fuel rail and has a small pin in the center of it. With a rag in your hand, hold it over the valve, and with the key on, use a small screw driver and push the pin in-the rag will keep you from getting sprayed, if all is alright, but if you get little or nothing, you have a problem with your fuel pump, filter, fuel regulator or you may have a plugged 'sock' at the bottom of the tank.
Jul 19, 2011 | 1995 Jeep Grand Cherokee
Jeep grand cherokee slow to start
THE THINGS YOU MENTIONED WON'T AFFECT CRANK SPEED. YOU'RE BATTERY IS PROBABLY ON THE WAY OUT THE DOOR. LOOK FOR CORROSION AND LEAKING BATTERYLIKE AROUND TERMINALS AND POSTS. BATTERY IS PROBABLY LOW ON CCA'S. NOW IF TALKING ABOUT WON'T START AND TAKES LONG CRANK TIMES IT CAN BE FUEL PUMP LOSING PRESSURE IN FUEL RAIL OR LACK OF FUEL PRESSURE CONSIDERING WHAT YOU MENTIONED. EVAP SOLENOID WILL USUALY SET A CHECK ENGINE LIGHT AND WONT AFFECT STARTING USUALLY UNLESS YOU HAVE A HUGE VACUUM LEAK
Jul 13, 2009 | 1997 Jeep Grand Cherokee
1997 pontiac grand prix with major issues
check all fuses for turn signal and brake lights.change fuel filter . first. do a little tune up change spark plugs and wires . if changing fuel filter dont help. have fuel pressure check first before buying a new fuel pump .they run after taxes 400.00 dollars. your fuel pressure should be 41 to 47 psi. replace fuel pump relay also.
Mar 16, 2009 | 1997 Pontiac Grand Prix
Car Audio & Video Logo
89 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
chargerhp
chargerhp
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
