Compresser over heating compresser
  • 49 Answers
You need to make sure your condensing fan motor is working properly, condenser coil is clean, if both is proper you could have a weak capacitor or the system could be low on freon.
Posted on Feb 17, 2008
  • 26 Answers
May be this tripping your compressor,please check the continuity of the following..
1) Continuity of Compressor if this a loose compression
2) Continuity of Capacitor if this a low capacitance or not functioning.
3) Check the power voltage.
Go to the nearest shop for repair the units,thanks
Regards,
Edgz
Posted on Feb 16, 2008
1993 nissan quest wont start after over heating
Overheating will damage the head gasket and the cylinder head.
Insufficient compression in the cylinders due to leaks and the engine will not start. To begin with run a compression check on all cylinders and then any cylinder with compression not at spec run a leak down test to see where the compression loss is going.
Jun 27, 2016 | Nissan Cars & Trucks
How do you know when vehicle has jumped time, or blew headgasket?
have a compression test done to check compression pressures and ring condition
over heated engines leave the rings soft/broken and not sealing on the cylinder walls
it will be rare if the valve timing changed from over heating==more likely a burnt valve
Apr 29, 2016 | Oldsmobile Bravada Cars & Trucks
Is the condenser inside the unit
In a window unit the condenser is in the unit and is at the back of the outside section. With a split system or whole house cooling unit the condenser is always outside. The condenser compresses the cooling gas after it picks up heat from the inside evaporator, and forces the heated gas through a coil with a fan blowing through the coil to drive out the heat. A gas can be compressed, but the amount of heat it contains remains constant. A compressed gas will be hotter than non compressed.
Jul 26, 2015 | Heating & Cooling
I have a 2006 350is Lexus that has over heated. It has over heated and won't start back up all it does is turn over
What has happened is you have Warped the Head and lost Compression in the Engine. Without Compression, no Fire due to the Low Compression. Sorry....
Jul 20, 2014 | Cars & Trucks
2002 jeep liberty heat only works at high rpm
Sounds like low flow issue. Flush and clean system, PROPERLY! Buy a flush kit, drain system, blow compressed air through, fill with cleaner/water mix, run for 30 min with heat on, drain system, blow out with compressed air, fill with water, run for 30 min, drain, blow out with compressed air, fill with 60% coolant mix.
Nov 26, 2013 | 2002 Jeep Liberty
Burning water for my toyota 1989 2.5 engine
Burning water in the engine means white smoke from your exhaust system. And compression expulsion from the cylinders to cooling system witch create over heat and pressure on radiator TK test can confirm that. If is not over heat . Is your inlet manifold gasket leaking in to compression champers .
Sep 22, 2012 | Cars & Trucks
No heat , an engie overheats. got new thermostat. an water pump` flushed out rariator an heatercore
check clutch fan or electric fans on radiator, check blend door in heater assembly under dash for no heat
Oct 29, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
My laptop is DELL XPS M1330. It heats up and then slows down the machine.
Inside your computer, any dust acts as an "insulator", preventing the heat "radiator" inside your laptop from dissipating the built-up heat. So, remove the dust:
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Hold the can upright, and blow compressed-air into every hole and slot in your laptop.
Reconnect everything.
Apr 02, 2010 | Dell XPS M1330 Laptop
A/c not cooling
it sounds the problem with the compresser.or may be ur compresser is getting heated quickly and stops working which stops cooling.
Dec 17, 2008 | Whirlpool ACE244XS Air Conditioner
Heating & Cooling Logo
254 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
