Question about HP iPAQ rx1950 Pocket PC
What's max mem size for ipaq 1950
I recently purchased a 1 gig mem card for my HP Ipaq 1950 pc and in the setup it doesn't see the memory or the storage size when I added it. Is there a maximum size for this device
  • Anonymous Apr 16, 2008
    I have installed a 2G Memory Card into my HP PDA 1950 and it doesn't recognise that it is there. It keeps telling me I am low on memory. How do you get the PDA to recognise this?
  • 29 Answers
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Posted on Feb 26, 2008
Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Mar 01, 2009 | HP Computers & Internet
Want to increase memory above 1 gig. compaq nx9010
You may have incompatible memory module. Just put in one memory module in at a time to see if it boots up, this will determine which module was not compatible.
Nov 15, 2008 | HP Compaq nx9010
Storage card
see http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1227806916727+28353475&threadId=1174150
Nov 04, 2008 | HP iPAQ rx1950 Pocket PC
Compaq Ipaq 3955
to backup your files contacts and everything you need to have a backup program.
spb has high quality software
http://www.handango.com/PlatformProductDetail.jsp?linkShareSite=linkShareSite&productId=182078&siteId=1
more of their great programs and games can be found here
http://www.spbsoftwarehouse.com
You can put your programs on the storage card by selecting another install location in the setup.
as I've explained in this tip
http://www.fixya.com/support/r659379-installing_games_software_pocket_pc
You can also use the file explorer to copy and move your files into the storage card for save storage note that the programs might not work if originally installed into main memory and then copyed into a storage card.
Comment by Ekse, posted on Jun 20, 2008 use this link instead of the handango one.
http://www.spbsoftwarehouse.com/products/backup/?en
Jun 20, 2008 | Compaq iPAQ H3955 Pocket PC
I have an ipaq 1950 but i cannot use it!!! can anybody helpme? when i start it, appear in the screen the aligne step... but stay on that forever... what can i do to go on to next part of the setup.. thanks...
It is ovbvious from the Picture that your screen is cracked. You will not be able to comlete the alignment without fixing that first. Contact HP or a local HP repairer
Jan 20, 2008 | Compaq iPAQ H3630 Pocket PC
PAQ 5550 and MMC 4.x (Plus)
so MMC cards are the older version of SD cards. Ipaqs support the fast SD cards and all sizes up to the max.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
Storage question for Ipaq
You have too many files in your root folder... Create a subfolder and copy the files into it...
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ rx1950 Pocket PC Logo
755 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
