Question about GE JGBP24 Gas Kitchen Range
My oven doesn't light
My oven suddenly doesn't work. The burners on top work fine. The broiler works but the cook part of the over won't light. No gas smell when it is turned on. Any ideas?
  • 2 more comments
  • CORKYD Mar 04, 2008
    Over night, my oven quit heating. The broiler and top burners work fine, but the oven (on bake) will not light. Any ideas? Thanks in advance.
  • greggsquires Oct 06, 2008
    range works but the oven does not get hot
  • hamp1962 Jan 24, 2009
    Having the same problem. Broiler works, but Bake doesn't. Ignitor doesn't lite up. I pull the panel at the top of the stove to check the fuse, but am having trouble identifying it. Do you have a part number I can look for?
  • Anonymous Mar 28, 2014
    burners and broiler work
I'm assuming that the fuses are located behind the clock and dials panel, right?
Thanks
Posted on Aug 04, 2008
  • 77 Answers
You should check your fuses located in the top of your stove
Posted on Feb 16, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
My gas oven is not working-just used this afternoon for bread and chicken-it was fine-broiler and burners work ok
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 | GE Ovens
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
GE JGBP24 Gas Kitchen Range Logo
396 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
