Question about Marantz CD-67 SE CD Player
Marantz cd 67 mark 2 (Original SE)
This player, tho a few years old has not been used that much but will now no longer recognise when any cd is in the drive tray. I've run a cleaning disc on the machine but it has made no difference. Any idea what's wrong and can I get it fixed or do I just buy another more reliable playert ?
John Willis
Tel 07939 148603m
email Donnijonti@aol.com
  • 77 Answers
You might be able to get it fixed future shop can take alook at it and tell you if it can be fixed
Posted on Feb 16, 2008
What would cause a panasonic cp 67 dvd/cd player to play only cds. How do I adjust the reader?
It is most likely a permanent fault as CDs and DVDs require the laser to focus differently. If the unit is a few years old it will not be viable for economic repair.
Aug 22, 2014 | Televison & Video
What format audio files play on Marantz cd67? I've tried .m4a, .aiff and .mp3. The .mp3s are in a folder - might that make a difference?
Replace with a Philips VAM1202 Laser pick-up.
This is a revised version of the CDM12.1 and has a very good reliability
record.
If you replace with another CDM12.1, there's no telling when this
will also pack up as these have a very high failure rate.
Oct 02, 2010 | Marantz CD-67 SE CD Player
A cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot...
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
Marantz cd67se mk 2 Door does not open when button pressed
i had the same problem on a marantz cd-63 which is virtually identical
and it turned out to be a faulty button on the control PCB.
i replaced it with one out of a scrap PCB and all worked as it should.
hope this helps.
Dec 13, 2009 | Marantz CD-67 SE CD Player
My Marantz CD63SE SPECIAL EDITION CD PLAYER won't read discs
Most likely, new optical (lazer) pick up required to solve this issue.
Nov 30, 2009 | Marantz Audio Players & Recorders
Won't recognise cd
A few possible causes:
- dirty or oxydized power switch contacts
- dirty laser pickup lens
- faulty laser emitter
- faulty laser pickup sensor
- dirty or oxydized contacts on any connectors, including flat foil cables
- oxydized brushes and commutator on spindle and/or slide motor
- dirty or oxydized contacts on the door switches
- faulty power supply (filter capacitors, voltage regulators)
- faulty motor driver IC
Could ba any of the above causes or a combination thereof.
Hope you can locate the actual fault.
Regards,
Triarcuate
Oct 17, 2009 | Marantz CD-67 SE CD Player
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
I have a marantz cd 67 se cd player.it doesn't always play cd's.it appears that it fails to recognise there is a cd in the cd drawer. also when it does actually play it often stops playing part way through...
Hi dr dray
Your player has a CDM12.1 laser transport fitted to it. They suffer a couple of problems that can be fixed that stop em from working so well. If you are handy with a screwdriver, then I can talk you through it.
regards
Robotek
Apr 27, 2008 | Audio Players & Recorders
393 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
