LG AC/compresser over heating compresser.
  • francis rivero May 11, 2010
    jobe 21, your post is very basic, kindly elaborate so that i can help you why the compressor is over heating. tnx
Check all air vents closely for accumulated carpet fibers, dust and gunk that may have accumulated and vacuum thoroughly.
Posted on Feb 17, 2008
  • PiRSquar Feb 17, 2008
    check all air vents VERY closely for accumulated carpet fibers, dust and gunk that may have accumulated and vacuum thoroughly.
I have LG 'Intello air' 1.5 ton window ac. I want to know if it can be changed into a heater by fitting a reversing valve. If so, will LG service people do it? How muchwill be the cost? Will it harm...
You can't change the a/c model fr' cool to heat & cool model.It's my sincere advise go with new heat and cool a/c. Normally Window a/c coming with heater coil.
Dec 11, 2010 | Heating & Cooling
Compresser overheat triping
Hi!!
It could be a few things that make the compressor overheat, when this happens, the bimetal thermal protector shuts it off to avoid damage to the unit.
Some of the reasons could be:
Dirty condenser and/or evaporator (if condenser is dirty or clogged up, the heat absorbed by the evaporator will not be dissipated, this will cause the compressor to overheat.)
Bad fan motor.(not blowing enough air to cool down condenser).
Bad capacitor (only if compressor fails to start right up or not at all.)
Worn coils inside compressor.
System clogged or dirty. (If the system is dirty or clogged up, the compressor's workload increases causing it to overheat.
Don't forget to rate this post, Good Luck!!
Jul 01, 2010 | LG Art Cool LA121CNP wall/window Air...
My laptop is DELL XPS M1330. It heats up and then slows down the machine.
Inside your computer, any dust acts as an "insulator", preventing the heat "radiator" inside your laptop from dissipating the built-up heat. So, remove the dust:
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Hold the can upright, and blow compressed-air into every hole and slot in your laptop.
Reconnect everything.
Apr 02, 2010 | Dell XPS M1330 Laptop
What is the presure of the LG WINDOW AC compresser .we perchesed it in2005.last year we found that it was not cooling so we called AC man he said that gas has to be fill ,he did it .again this year also we...
If he is having to continually recharge the unit, the unit has a leak in it. The leak would have to be located before the cost of repair could be determined.
Feb 24, 2010 | LG Heat cool Window Air Conditioner
Fan for front not blowing ac compresser not coming on or
sounds like your restrictor box is takeing a ****.. does it work on any of the 4 fan speeds?
Aug 04, 2009 | 2004 Honda Pilot
I have a LG window AC Model LWHD8008R. Won't power up?
Replace reset switch or bypass it to make sure it is the problem. Check for low voltage while the unit is on. Shoud stay above 105 vac
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
