Question about Dell F3534 Touchpad
Im using a DELL LATITUDE D620 the touchpad isn't working and one day I found out I have to +ALT to move my cursor on the touchpad,anyway to fix this ?
    Novelist:
  • 84 Answers
Looks like you may have inadvertently pressed the Function (FN) key associated with the touchpad. try re-enabling it by pressing Function(FN) and the corresponding F key. For my computer it's F5...but on others it has been F7...just look for the symbol that looks like a touchpad. This should cover it. (: Good Luck!
Posted on Feb 25, 2010
The best solution I found was to restore your computer to a previous time before the touch pad got messed up here is what I did
Go to Start menu-> My Computer-> Control Panel-> Performance and maintenance-> System Restore (on the left panel)-> Restore my computer to an earlier time-> Choose any date then press Next-> and Next again->and you should have tour touch pad working again. ^.^
I'm so happy I got mine working again been working on it for 2 days O.O I was going to get in trouble if I didn't do it.
Posted on Aug 16, 2012
    Genius:
  • 1,189 Answers
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect.
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
Hope this Fix it.
Posted on Jan 28, 2010
SOURCE:
My mouse is not working on my laptop, it wont move
Hello debbiestar34,
Typically on a laptop computer there is an extra set of keys called the function keys. You will notice these keys are identified (usually) by a different colour of text on the keys of your keyboard.
You can probably find a key labeled "Fn" or "Function" in the bottom left of your keyboard, between the "Ctrl" and "Alt" buttons. Once you've found that key, look at your other keys and you should see one that somewhat resembles the touchpad on your computer or a simple rectangle with a mouse cursor inside it.
If you've found both of those keys, start by pressing and holding the "Fn" key, then press the one for your touchpad then release both keys. That should work.
May 25, 2011 | Dell Latitude D410 Notebook
Good mornning , i have dell d620 laptop (latitude) and i removed the original vista windows were on it when i bough it and installed windows 7 , i need to know is my laptop model match with window 7 or no...
All the vista drivers can be used for 7. By default, windows 7 installs all drivers except for touchpad.
You can find 32 bit version for it here
The 64 bit of Windows 7 64-bit ALPS touchpad driver from the Dell support site for a Latitude E6410 is reported to also work for D620. Give it a try.
May 11, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a new Dell Latitude E6410. While typing the cursor moves automatically causing inserting/erasing text. How do I fix this?
I'm assuming you are using some version of MS Windows.
I found this on the Dell support website;
  • Click Start.
  • In the Search box type main.cpl, click main.cpl in the list of programs.
  • In Windows XP click Run, type main.cpl in the box next to Open, click OK.
  • Click the Dell Touchpad tab.
  • Click on the picture of the touchpad.
  • Click Touchpad Settings.
  • Make sure there is a check in the box to the left of TouchCheck, move the slider bar all the way to the right (this can always be adjusted back).
  • Uncheck the box to the left of b>Tap to Click.
  • Move the slider in the Touch Sensitivity area to the right until it is 3/4 of the way toward Heavy Touch.
  • Click Apply, then click OK.
  • Click the X in the upper-right corner to close the Dell Touchpad Utility.
Hope this helps ;)
Feb 02, 2011 | Computers & Internet
Hi. the touchpad on my Dell Latitude D620 has somehow been disabled or jus quit working..idk which. so am trying to install a ge wireless optical mouse HO97985......WK2004 with usb receiver.how do i get...
If it was disabled try this. push the FN or function key, found near the lower left of the keyboard. Hold that down and then push the F10 or F12 key. Should be F10 on that model. That should turn it back on. The pads are pretty reliable and I've actually only ever seen one die in about 15 years.
If you are stuck installing then plug the mouse in and boot. It should actually find the mouse as new software and install a default driver. You may have to reboot it once after before it works. To work without a mouse you use the tab and spacebar. Tab mose from one box to another and space acts like a mouse click. Alt tab moves from one program to another. And to close use alt -F4 and to shut down use alt-f4. You shouldn;t need to do that if you boot with the mouse in the usb so it finds it.
Jan 20, 2011 | GE Wireless Optical Mouse
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Dell D620 cursor not working- floating all over screen, mouse and touchpad not effective
you will need to reload the drivers with dell laptops there is a order in which you have to install the drivers it is shown on the right side of the drivers download page
Jul 16, 2009 | Dell Latitude D620 Notebook
Touchpad right and left clickers womt work
this is due to the driver missing or uninstalation of the touchpad you must try to reinstall the driver again.
for any harware problem you can check the status in
DEVICE MANAGER present in CONTROL PANNEL(WINDOWS VISTA)
for
WINDOWS XP you can search this application in windows search.
Apr 20, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Touchpad going crazy...
set ur mouse button to default or reinstall ur drivers this may fix ur problem.
Feb 13, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
3,333 people viewed this question
Clive
Clive
Alun Cox
