Audio I wish to connect a mono headphone set to my LG LCD TV model no. 32LX2D. Is this possible and if so where do I plug in the jack? Joan ASustralioa
    Brigadier General:
  • 6,966 Answers
Hi Joan,
Unfortunately there is no built-in jack for either a stereo or mono headset for an LG 32LX2D.
There are possible ways of doing these, they are:
1. Connect by RCA cable the Aux In of an external amplifier that has provision for headsets to the Composite Audio L/R Out of your TV;
2. hardwire a jack to the internal speaker wires of the TV. If the internal speakers will be cutoff, you need to also install internally a loading resistor. This would require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron.
If your concern has not been addressed after completion of the above procedures or you are not comfortable on a DIY (do-it-yourself), you may need to seek the services of a qualified professional or your friendly neighborhood electronics shop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 16, 2008
I have a 32inch tv but cant find headphones jackplug
In some models there would me no headphone jack. May it only have RCA audio out and optical out.
If you wish to get some details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 22, 2016 | LG 32LD450 32 In. LCD HDTV
How do i find the headphone jack on a toshiba lcd
Unfortunately, not all Toshiba TVs have a headphone jack, The 40E210U is one of those models. The above referenced model only has digital audio out. You would need a digital to analog audio converter and then RCA stereo to 3.5mm adapter to plug in most headphones.
You can always look on the back and side of your TV and look for a 3.5 mm port with a headphone symbol. If you have a different model, many Toshiba product manuals are available here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp . Click on Product Support and then use the drop-down menus to select your product. Then click on the GO! button and choose the User's Guide tab.
I wish that I had better news for you.
Dec 01, 2012 | Toshiba 40E210U 40 in. LCD TV
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Lg lcd tv 37lc2d no headphones socket - how do i connect headphones?
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Mar 17, 2010 | LG 37LC2D Television
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
Jan 21, 2010 | Vizio VO47L 47 in. LCD TV
Have new lcd hdtv. Have old headphones can they
Yes. 2 possibilities:
1 - the new tv has a headphone jack - just plug them in.
2 - no headphone jack - buy a RCA to phone jack adaptor, plug it in the audio line out RCA connectors, plug the headphones into it and mute the tv.
Dec 06, 2009 | Televison & Video
Our tv loses power intermittently but after a few minutes when plug is removed the power is restored. are there known problems with this adaptor or is it the tv
There is a possibility that the jack in the T.V. is wired for mono and the plug you are using is stereo. This means that the stereo plug would short circuit the jack and affect the output stage of the sound. These jacks were used on older T.V.s. Go to your local electronics store and see if they can sell you an adapter to convert the stereo plug to a mono one. Check your manual for the T.V. first to make sure that this is indeed the case. Hope this helps.
Nov 16, 2009 | Philips SWA2035 - Audio adapter -...
Televison & Video Logo
397 people viewed this question
Top Televison & Video Experts
