Question about Sony Playstation 3 (PS3) Console
Ps3 problem When i turn on my ps3, nothing seems to be displayed on the tv. All the lights on the ps3 are on and all the buttons are working. ive made sure all the cables are connected properly Adnan
  • tedrow44 Feb 16, 2008
    i get no vido on screen but no games,dvd,cd
    Problem Solver:
  • 18 Answers
Soun like your display settings are messed up do you have your HDMI cor you will need it to reset your settings or call sony
Posted on Feb 16, 2008
Had the ps3 working fine, plugged it into another tv and nothing, the tv wont pick up the signal.. went to plug it back into the 1st tv and still nothing
Try resetting the display back to standard definition -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Wait for the PS3 display to reset
Hope this helps
Oct 26, 2010 | Sony Playstation 3 (PS3) Console
Ive turned on my ps3 but i cant see the screen on my tv
Hi there, please try the following steps :
Step 1 Turn the PS3 off into standby (red light on)
Step 2 Press and hold the power button. It will beep when you first press it and then beep again 5 seconds later. Release the power button when you hear this second beep
Step 3 Wait for the PS3 to boot up
This basically resets the video display back to standard definition.
Hope this helps and thank you for using FixYa
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
When i connect my ps3 to my tv there is no picture but i can hear sound ive tested the wire with a friends ps3 and theres nothing rong with it and ive set it up on a difrent tv and it still had the same...
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Aug 22, 2010 | Sony Playstation 3 (PS3) Console
What do i do when my ps3 turn on, and nothing comes on the tv?
Sounds like you video display settings have been messed with. You can reset this by turning off the console so that the red light is on. Then hold down the power button for five seconds,it will beep a few times.If you have red white and yellow a/v cables laying around for the ps3 unplug the hdmi from the tv and the ps3 connect the a/v cables then turn it on. If you have picture,plug you hdmi into the console and the tv then go to display settings on the ps3 and set it for hdmi out.that should work.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
Tv says "no signal" when i turn on PS3
About holding the reset button, I assume you know how to use that trick, you might be missing something, though: Probably you have your TV set to the incorrect input, eg. Connect only the HDMI, set your TV to HDMI input and go with the power button trick (press (youll hear a beep), dont release until you hear a second beep) the system will autmatically display through HDMI, it can take up to 5 secons or so.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Im trying to get my ps3 to connect with another tv
turn off ps3 till the red light is on the machine then you need to hold down power button to turn on until you hear a beep.
make sure a hdmi cable is not connected at back of ps3.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and nothing comes on the screen! the sound works but nothing on the screen! ive tried to hold the power button but nothing happens
Check the following:
First try plugging in a VCR or DVD player and see if you get a picture. If not, try changing the video cables. It may also be that your TV video jack isn't working. Which in that case you will have to get a new TV.
Apr 15, 2009 | Sony Playstation 3 (PS3) Console
No picture (No Anything on screen)
Can you describe your ps3 and how did you connect it to your tv?
Try connecting your ps3 to another tv.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
