Question about Philips 50P8341 50" Rear Projection Television
Philips 55p8342 chassis ptv916
I need a new remote and my colors are really cloudy
  • Anonymous Nov 14, 2008
    mines is doing the same/ how much would it cost to be fixed. or can i do this myself?
  • 927 Answers
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Posted on Feb 23, 2008
Do not have remote for ptv916 and universal does not work. Went thru every code 4 times....
As with almost all phillips products universal remotes just do not get the job done; If the model number is 9P6034C try this link:
http://www.everytvremote.com/remote-control/philips-magnavox/tv/9p6034c.aspx
If it is a different model number: GOOGLE THE MODEL NUMBER WITH THE WORD REMOTE AFTER IT, LOTS OF THEM AVAILABLE.
If you have questions or need help comment here.
SD TECH
May 11, 2011 | Philips Magnavox 9P6034C 60" Rear...
I have a PTV916 Model # 60P8341A. I cleaned the lenses and the mirror inside the TV however, I can see alot of dust inside the actual lens. Is it possible to clean the inside of the lenses?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Philips 50P8341 50" Rear Projection...
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Couldy image
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 14, 2009 | Philips 46PP9302 46" Rear Projection...
Cloudy screen/
More than Likely your Tubes are getting weak!, (3 tubes - Red, Blue, Green) Need Replacing or Rebuilding (fluid change). g.
Jun 26, 2008 | Philips 60PP9202 60" Rear Projection...
Autolock on my philips magnavox 60p8342
I am sending the user manual to your email address it will explain the auto lock procedure.
Jun 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 55P8342 Bow in picture
Replacement IC's suspect...did you use generic ? For all my repairs where originals are STK392-110,120 or 150....I use the
up-grade STK394-160E Mfr by SANYO with Hitachi part number
CZ 01341...they are expensive,but NO RE-CALLS ! Also,did
you check the resistors close to the IC's for over-heat damage ?
...........................................T.
Feb 21, 2008 | Philips 60P8342 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
309 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
