Question about Olympus EVOLT E-300 (Double Lens Kit) Digital Camera
Camera does not work when memory card is inserted
My camera works perfectly when there is no memory card in it but as soon as I put a memory card in it will not power up and the screen shows nothing, and I cannot take photo's. The battery's work and so do the memory cards. Also the SSWF occasionaly flashes I have 2 freshely charged battery's and 2 memory cards and have tried combinations of them all with no change. Please help Exactly what I am having with mine, 3 bat 2 new mem card, works great till you close the dang door,then black! HELP
  • 7 more comments
  • Michael Iriwn Feb 16, 2008
    pins are all straight and present,
    it has, I havew trie 2 Fully charged battery (tried 2 of them) 2 Memory card ( 1 brand new)
    When the battery is in, memory card in, I turn it on and nothing, LCD screen is blank, I get a SSWF flash(blue) occasionally and I get a Red Led flash from on top of the memory compartment.
    IF I open the card cover, it reports card cover open on the LCD Screen, Close it and it goes black again. I take the memory card out and the camera works fine, I can access all the items on the screen, focus, etc.
    I do not think it is the card reader as when the card cover is open, with the card in, it tells me the cover is open, I depressed the pin or detent switch by hand it dies or goes black
    cards read fine in my desktop
    BUT it works without the card in it,zoom,auto focus,shuter etc,
    IF the ccd was bad, it would not work at all,just like the shutter. If it did not work or was slow or stuck, it would not matter if the card was in or not. Like a light switch either on or off, no in between
    I have reformatted, I just reformatted both of them again.
    Next idea?
    I do not know if it is in high angle mode, but I have set it back to factory defaults.
    Olympus E-300
    OK,
    With this camera, with fresh battery,new media card and card cover closed, I get nothing on the LCD, I get intermittent flash from the SSWF and the red led on the memory card indicator. NOTHING ELSE WORKS.
    If I open the card cover door, the lcd displays Card Cover OPEN, and I cannot do anything.
    IF I take the card out, IT displays LCD, I can take pictures ( cannot store them) but the auto focus works and everything is as it should be. I can access the menu and have reset everything back to default
    IT seems to go dead when the detent pin/switch is depressed on the card cover door .
    I have charged 3 batteries and tried them all, Have 2 memory card,1 a brand new Lexar 2 gb , the other an older Kodak 1 gb card. Both work fine in the desktop card reader. Have formatted them several times to no avail .
    Have checked the pins in the card slot, all appear to be clean and straight, no corrosion what so ever.
    I have tried differnt lens,still no good
    HELP, this is driving me crazy
    OK,
    I AM SURE that the card are in the right way ( dont fit the wrong way) If you read my preivous post you will see that I ave used several cards
    Well, I thank you for all you time and trouble, still does not work. Thanks for taking the time
  • syslogix May 06, 2009
    I encountered exactly the same problem just this morning with my E-300. I had been using it for 2 years already and suddenly I can no longer use it. I tried all the suggestions here except consulting the service center. Any chance that this problem was already resolved?
    Regards,
    Genius:
  • 1,665 Answers
Make sure you are inserting memory card correct, and pini are clear.If is possible try another card.
Have a look at following link instructions.
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/esystem/man_e300_en.pdf
Posted on Feb 16, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Feb 16, 2008
    Unfortunately your camera must be taken to an authorized service station because board may have cracks or memory socket is damaged it is impossible to repair at home.
    Master:
    Sergeant:
  • 462 Answers
Try to format for once the memory card throughly and try it again else try another mwmory card, if both fails, take it to ur service centre...!!!
Thankyou
  • Mohamed Ismail
    Mohamed Ismail Feb 16, 2008
    The best thing at this stage is stop breaking ur head and take it to the service centre..!!! This looks like some hardware malfunction...!!!
    Thankyou
  • Mohamed Ismail
    Mohamed Ismail Feb 17, 2008
    I must say for once to take it to the service centre for it looks like a major issue...!!!
    Thankyou
    Genius:
  • 3,422 Answers
It sound like a bent pin issue.
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in.
From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break.
I strongly suggest you to get it repaired if you can't it by urself.
Goodluck..
  • 5 more comments
  • Priya darshan Feb 16, 2008
    click HERE to download advanced manual.
    Click HERE to download the quick start guide.
    Normally there are two reasons for the given problem.
    1). Bad or defective CCD. and/or
    2). shutter not working.
    in
    the first case the only solution is the replacement of the CCD.
    Please click HERE
    And in
    the later case sticking of shutter blade, non functioning of shutter
    blade will cause the problem. This can be rectified by sending it to
    some repairer.
    Please read this:
    in
    Please click HERE
    And in
    some repairer.
    Do one thing try reformating ur memory card and then give it a try.
    Is the camera in high angle mode?
    hey check THIS link out hope it will help ya..
    See i have already given you all my best solutions and even the other experts have told you to get it repaired.
    Genius:
  • 3,587 Answers
Ok...it appears that your card reader is really in trouble. Can you inspect the inside, to ensure that no gunk crept inside? That would explain some of the issue.
Can you test those memory cards on a reader on a laptop, to ensure that they are not corrupted, just in case?
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
Camera stop working after I put the memory card
The camera may not support a 2GB memory card, or the card may not be formatted properly.
May 09, 2009 | Cameras
Can't format memory card in A510 Canon digital camera.
Have you used this card in the past? Is this a new card?
Is this card rated to be used with this camera. Some cameras can only support cards of certain sizes.
If the card is compatible, take the card to target or best buy and format it on a camera there and see if it works then put it back in your camera and see if it works after.
Mar 07, 2009 | Canon PowerShot A510 Digital Camera
Can't reformat my memory card
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 25, 2008 | HP Photosmart M425 Digital Camera
    I have had this problem, and it was a bad CF card. Are you sure both of them are good? If a computer can read them, maybe try formatting them.
    Dec 05, 2007 | Canon Digital Rebel / EOS-300D Digital...
    Camera won't work if the memory card is inserted
    Don't know if that works for you.
    I just use another memory card.
    I have 1 card my P505 doesn't work with.
    Others are fine.
    Hope this helps.
    Rosi
    Oct 16, 2007 | Casio Exilim Pro EX-P505 Digital Camera
    Camera will not read memory card
    Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
    May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
    just look in the slot for a short circuit. some times it does hapen on cf cards or on xd cards.
    Jan 04, 2007 | Olympus EVOLT E-300 (Double Lens Kit)...
    Olympus EVOLT E-300 (Double Lens Kit) Digital Camera Logo
    1,229 people viewed this question
    Top Olympus Cameras Experts
    Steven Wander
    Steven Wander
    Jerry Greenberg
    Jerry Greenberg
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
