Recieiver HDMI not working with ps3
I have a TX-sr575, two hdmi cables one plugged into the out (receiver) to the tv and the other from the ps3 to the hdmi in. I have tried to change the video settings for the correct 'ins' for various components but no luck.
I fixed it by selecting the dvd option on the control, which gave video but not audio, this model only outputs hdmi video and you need a seperate digital cable for the audio, in this case I want to exchange it because I want a system that does both audio and video by hdmi. Would you know any around the $1500 mark?
Posted on Feb 16, 2008
I'm using HDMI through my Onkyo SR575 receiver, but I can't get the audio to come through
Through to where? The attached speakers or the TV?
Digital audio must be assigned to hear it on something other than the default input selection. I can't find a manual but I hope YOU have one. Many receivers also have a choice to pass (or not) audio through the HDMI going TO the TV. Sometimes it is exclusive, meaning audio to the TV and NOT to the speakers.
Jul 09, 2011 | Onkyo TX-SR575 Receiver
NO audio on my TV/PS3 while TV connected with receiver via HDMI
Check the audio settings in the PS3 console. Then check the firmware version of HDMI that your receiver uses. It may be listed on the manufacturers webpage or in your manual. It must be 1.3a or 1.3b in order to work with your PS3. The downside to this is that there is no firmware "patch" to correct the problem. If you still have issues, post a reply on this thread and I can help you further and give you some options that "Will" correct the problem without degrading video and audio. Hope this helps.
Jun 16, 2010 | Onkyo TX-SR605 Receiver
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Ps3 and onkyo receiver
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Nov 09, 2008 | Onkyo TX-SR803 Receiver
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Problems getting my ps3 to work with the reciever.
cheak setting in ps3 and use 720 p not all sterios handle 1080 p tranfer best u put ps3 directto tv then optical cable from tv back to sterio on a ch ok
Jan 20, 2008 | Pioneer VSX-84TXSi 7.1 Channels Receiver
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Nov 26, 2007 | Onkyo TX-SR605 Receiver
115 people viewed this question
 Grubhead
Grubhead
