Question about Fisher and Paykel GWL11 Top Load Washer
Washer won't drain
Sears Kenmore probably 25 years old. Great machine. The water won't drain, all it will do is wash. I've tried changing the cycle with no luck, just keeps washing. I probably need a new washer but would like to at least get the water out. Thanks for any help.
Jann
  • 15 Answers
I just tried to post a lengthy solution based on the assumption that your washer is a Whirlpool belt-drive and that one of the solenoids on the wigwag is jammed. Unfortunately the system ate my solution and won't give it back. THAT'LL learn me to click on "More Options"!
To make it brief:
1. Determine if your machine really is a Whirlpool belt-drive and has a wig-wag.
2. If so, determine if the solenoid (on the wigwag) that shifts the machine into agitate is stuck.
3. If so, see if you can unstick it and let the machine shift out of agitate by itself. If not, see if you can remove the stuck solenoid (perhaps wigwag and all) and slide the shift bar yourself.
4. If you can just get the machine into neutral, even if the motor isn't running you should be able to lower the drain hose into a bucket and empty the water that way. As I recall, there's a valve near the pump that prevents the water from draining while the machine is in agitate mode.
Posted on Feb 16, 2008
  • gophersnake Feb 16, 2008
    Perhaps a moderator (or the local equivalent) could move this whole discussion from the Fisher & Paykel blind alley it ended up in to somewhere more appropriate -- Kenmore? Whirlpool (belt-drive)?
    Sergeant:
  • 288 Answers
You may want to look into the possibility that the water pump is not working. It may even be just clogged with clothes fibers. As it is a Kenmore, it is made by whirlpool, and pump for that type is a fairly simple repair, it might be worth keeping. As for getting the water out because you want to get rid of it, a siphon hose is the simplest route without taking anything apart.
Probably no hope. The washer is an old Kenmore (25 yrs.) It worked fine until today it only fills w/ hot water, and then only very little. Should I put it out to pasture?
Well, it certainly doesn't owe you anything - 25 years service is very respectable! You could have it checked - but investing more than a little money into a 25 year old machine doesn't sound like a good idea to me. Parts for your machine are probably going to be hard to locate, too. Newer machines do more with less water, energy, etc. If you lack the funds for a new, energy efficient machine - your choices may be limited to repairing what you've got - or picking up a newer, used machine instead. Used washers can be found for a fraction of the cost of new machines and many people change them because of color issues - not because they don't work. Check places like craigslist and freecycle for inexpensive (or even free!) replacements. In any case, knowledge is power.. price both new and used washers and maybe spend a few bucks to have the washer diagnosed. Knowing what replacement costs are compared to repair costs of a 25 year old machine (and maybe even an idea if the machine is going to have problems in the near future from the repairman), you can decide what fits your budget best.
I hope this helps and good luck! Please rate my reply - thanks!
Jun 29, 2011 | Kenmore 22622 Top Load Washer
Won't fill, no cycling noises
Hello, try to see if there's a good water volume coming through the hoses attached to the washing machine.If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to). If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Thanks
Jun 04, 2010 | Kenmore 24642 Top Load Washer
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Washer is not draining at end of cycle-puddle in washer at end of cycle -sears kenmore front loader 3 yrs old
Some of that is normal, if you turn the drum around you will here water. Mine do it also.
Feb 13, 2010 | Kenmore 44102 Front Load Washer
We have an Kenmore 70 Series Heavy Duty Plus washing machine that is about 20 years old. The washer stops after the wash cycle and we have to manually move the dial one notch. The washer then completes the...
This is the deal, your washer is way to old to fix. The board is going bad and that is why it will not cycle properly. It would cost about $150.00 to fix and that does not even include labor. Consider craigslist as you can find some great deals from 40-60 for a newer one. Hope this helps.
JimmyC
Sep 26, 2009 | Kenmore Washing Machines
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Washer won't drain
I don't know how it was fixed. I kept on running it through cycles and the water finally drained.
Dec 05, 2008 | Kenmore Washing Machines
Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Aug 04, 2008 | Washing Machines
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
71 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
