Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
How do you get the covers off? "Does not support this mode"
Well here I am again trying to get the covers off of an unfamilar device. I found the 2 screws at the bottom and removed them.. On a hp 1702 I just forced the sides open, pulling and bending to pop the cover off.. How do you get this mag cover off?
Problem indicates on screen "Does not support this mode" on power up, then screen goes blank. OSD doesnt work... blank screen... Does not support message looks good though for an instant...
  • OldNasaDude Feb 16, 2008
    solved cover removal
    Scholar:
  • 198 Answers
Posted on Feb 20, 2008
What are the codes for the RCA RCRP05B remote control
Programming Device:
  1. Turn on a device and, if applicable, insert video media.
  2. On the remote control, press a device key once; it will blink once.
  3. Press and hold Setup until the selected mode key blinks twice, then release Setup.
  4. Use the codes in the accompanying code list to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the selected mode key will blink twice. If the selected mode key emits a long blink, the entry is invalid. Repeat the above steps and try entering the same code again.
  5. Aim the remote control at the device and press Power once. The device should turn off. If it does not, repeat steps 2 through 4, trying each code for your brand until you find the one that works. If it still does not respond, try searching for the code (see "Searching for Your Code" below).
  6. Once you've found a code that turns your device on and off, test other remote commands for that device.
  7. Repeat steps 1 through 6 for each device you want the remote control to operate.
from - http://lifehacker.com/5770451/make-money-in-your-spare-time-doing-simple-online-tasks
May 02, 2014 | Apple iPhone4 4G iPhone 4
Tip
DISH VIP612 Remote Code Scan
DISH Solo DVR VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Acer web cam not working last 2 weeks,model of lap top is:aspire 5630
Check your device manager for the imaging device ( webcam )
If not found, try booting into safe mode and give a look again in device manager.
If you have any usb devices connected disconnect them
If all of this do not work, you may have disconnected the webcam or could be bad.
Hope this helps
Apr 08, 2014 | Acer Aspire 5600 Series 5630-6951 Laptop
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Televison & Video
Webcam no found in the sistem
Is you web cam works on that pc before?
if not update the Usb to 2.0
if yes go to safe mode removed any device with yellow exclamation mark under the Usb port in device mngr restart in normal mode and try again also remember to try different port and diff cable, you never know the cable might be damage..
Jul 07, 2009 | Acer Aspire 6930-6941 Notebook
Air conditioner not running properly
This is an Error code. Something shorted or fail to perform it's job, possibly a safety device found an error, and the system cannot function until fixed or possibly reset. I am unfamilar with this unit. Might try service technician, or if under warranty call dealer for tech support. Try unpluging unit for 5 minutes and then pluging back in...it may reset the trouble code and perform correctly this time.
May 17, 2009 | Haier ESA3125 Wall/Window Air Conditioner
I have a rca312w control and the codes to program my sylvania tv
Try these codes 0054 or 0030
How To Program Your Remote Control
  1. Turn device to be programed on.
  2. On the remote control, press a device key one (e.g., AUD, VCR, TV, or CBL). Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Locate the four-digit code found in the list below that corrisponds with the device you are programming then enter that four-digit code. If performed correctly, the selected mode key will blink twice.
    (NOTE:If the selected mode key emits a long blink, the code is invalid. Repeat steps 2 and 3 and try entering the same code again.)
  4. Aim the remote control at the device ad press POWER once. The device should trun off. If it does not, repeat steps 2 and 3, tryin each code for you brand until you find one that works. If it still does not work, try searching for the code.
  5. Repeat steps 1 through 4 for each device you want the remote control to control.
Nov 11, 2008 | RCA 3-Device Universal Remote with...
Calculator help for algebra 1
cryshug24 the mode(s) you want to use is mth IO and line IO for algebra. push the shift mode then #1. to write out a long equation push shift mode #2. you have to keep playing between the two modes to get the correct answer.
Jul 31, 2008 | Casio FX-115ES Scientific Calculator
Setting up for cox cable
Try this:
Searching the Code Library
(Program Code 9 9 1)
1. Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, or AUX)
until the mode keys blink twice. For example, to search for a TV code, press and
hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press . The remote automatically tests
each code in its library, beginning with the most common codes. The mode key
blinks once each time the remote transmits a new code. The mode key blinks twice
when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press or to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
8. Go to Which Code Worked to identify the code that controls your device. After you
identify the code, record the code in the space provided on the cover of this guide.
Jul 27, 2008 | Maxent MX-26X3 Television
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
167 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
