Question about Apple iPhone Smartphone
Iphone goes to "needs to charge mode"
Hello, my iphone is a 1.1.3 OTB and i only had it for a week now. When the battery gets below like 80 % i always get the screen where ill see the iPhone battery says it has to charge. When i put it to charge it goes right back up and functions again. With almost full amount of battery time left... So with other words i have to carry the charger with me wherever I go. Do anyone know what the problem is or what i can do?
When you bought the phone you musnt have left it on charge for 24 hours like you are actually meant to. so there are no known solutions for your problem. you can either ask for a new one sent out to you and tell them your problem or you can buy a battery portable battery charger that you can take around anywhere with you. they are approximatly 30 odd dollers.
hope i have helped.
waiting for your ranking.
Posted on Feb 16, 2008
Ate pro max error says unfortunately stock android has stopped. How to fix?
1. Charge The iPhone
It may sound easily, but you need making sure your iPhone's battery is charged enough to run the phone. To test this, you can plug the iPhone into USB charging port or the main USB ports on a computer. Let it charge for 15-30 minutes and hold down the on/off button to turn it on. Maybe it turns on automatically. If you doubt recharging doesn't work, it's possible that your charger or cable is faulty.
2. Check The iPhone Cable And Charger
Maybe you need trying charging your iPhone with another cable and another charger. Then try charging someone' s iPhone with your cable and your charger. If the iPhone cable and charger has problem, you must pay attention to.
3. Restart The iPhone
If the iPhone cable and charger are no problem, you need to restart your iPhone. Pressing and holding the Sleep/Wake button for at least 10 seconds, until the Apple logo appears.
Note for iPhone 7 and 7S users: Press and hold the Sleep/Wake and Volume Down buttons simultaneously to force a restart.
4. Restore The iPhone
If you want to restore the iPhone, you make sure you've got the latest version of iTunes. Then connect your iPhone to your PC and select Devices in iTunes.
If you haven't backed up your iPhone you will be told to do so now. This will back up all the data and settings on your iPhone. Then click on restore, wait until your iPhone completes the restore process and resets to the Home screen.
5. Reset
Click on Settings then General then Reset All Settings
This will perform a reset of all the settings to the factory defaults. The data or content on the iPhone is unaffected.
6. Put iPhone Into DFU Mode
Your iPhone may not turn on. This can happen after jailbreaking or when you installed an iOS update without enough battery life. When you face this problem, you can put your iPhone into DFU mode.
Plug your iPhone into PC.
Press the on/off button for 3 seconds.
Press the on/off button and Home button together for about 10 seconds. (iPhone 7 press volume down)
Release the on/off button, but keep holding the Home button for about 5 seconds.(iPhone 7 press volume down)
If the screen stays black, you're in DFU Mode. Follow the instructions in iTunes.
7. Force device into recovery mode
Beware: Recovery mode erases all the data on your device. Only follow these steps if you have a recent back up on iCloud or a computer.
Turn off your iOS device.
Plug the USB cable into your computer - but not into the device
Hold down the Home button then plug the USB cable into the device
When you see the Connect to iTunes screen (below), release the Home button.
More information about phone repair guides and tools, you can choose vipfixphone.com.
Dec 08, 2017 | Android Cell Phones
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
How can I improve my iPhone's battery life?
A recent research conducted on cellphones (smartphones) revealed that most of your battery life is drained by "Internet" and "calls". The more you use your phone for any of these two, the faster your battery drains. Next on the list is "Search for network" which consumes quite a bit of your battery power.
Smaller culprits are WiFi, Bluetooth, Screen brightness, themes, Vibration, etc.
* Reduce screen brightness to minimum
* turn off WiFi/3G/4G when not required (same with Bluetooth)
* if you are out of network area, turn off the mobile network so you cell doesn't keep searching for a network.
* If possible reduce internet usage on your cell phone to improve battery life (ie. if you have a laptop handy, use it!)
* Use a darker wallpaper
* Vibration takes up more battery than ringtones
* use a simple theme
* Dont keep your cell phone charging for long periods (eg. overnight)
* If you plan to buy a new battery, buy a branded authentic one
Hope this helped, thanks for using FixYa!
Apr 11, 2011 | Apple Cell Phones
My iphone wont turn on or charge please help
does you have tried following tricks? If yes, the battery is death and you can go to the next apple retail store and let replace the battery for 80 bugs or so... ex. tax...
1. Connect your iPhone to the charger
2. Hold the HomeButton and the StartButton together for 15-30 secounds
3. Now the iPhone has to restart
4. It's possible that you need to restore your iPhone with iTunes
5. If it's not booting, use the apple battery replacement program
I hope i could help you.
Best regards
Jan 30, 2011 | Apple iPhone 3G
My apple iphone cannot power on,just have apple screen on my screen with light turn on
hello!
This can be a result of a few different things:
1. make sure the battery is charged; if the IPhone has a low battery, a little battery icon will appear with a triangle exclamation on it.
2. the IPhone needs to be reset. You can do this by turning the hold switch to ‘off’, connecting the adapter to an electrical outlet, then press and hold the PLAY and MENU button for about 5 seconds
3. make sure the Hold switch is off; it should be switched away from the headphone jack port
May 07, 2008 | Apple iPhone Smartphone
Iphone does not ring on sleep mode
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
3. Reboot your phone
Apr 07, 2008 | Apple iPhone Smartphone
Locked phones
it's not as simple as it sounds unlocking the iphone! 1. do you have the 1.1.1 or 1.1.2 otb iphone? you need to do some research man! google it, the info is everywhere........really, before you start, you need to know the basics!
Jan 16, 2008 | Apple iPhone Smartphone
Iphone unlock code
These guys can help you get your iPhone unlocked. They are awesome! <a href="http://www.compdummy.com/">iPhone Unlock</a>
Dec 21, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
