Help with tv
I have a samsung tv model #HL-R5667W. I have sat. and a ant. hookup. The sat. pic. was green and wavy but you can hear it. I could watch with the ant. and get a pic. but you could see green lines in the pic. I could put the tv on the ant. and switch to pic. in pic. and see the ant. and the sat. clear. I called samsung and they said the cables are bad. So I disconnected all the cables and reconnected them and it worked for 5 min. it had streaks at the bottom of the screen. So I unpluged the power to disconnect the cables and reconnected them and I turn the tv on and it will not show a pic. it will run for 2 or 3 min. and turn off. I've had a tv repairman look at it and said it needed a color wheel. I can see it in back that the lamp is on. Help Me.
    Problem Solver:
  • 18 Answers
Does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Posted on Feb 16, 2008
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung HL-R5667W turns on for a quick flash and then no picture or sound. I verified I have good signal AV1 Sat rec. I switch over to TV/Cable and get nothing. I cannot change the channels either. I...
If you get on screen display with no picture and no sound, I suspect you have a failed digital board. Go to http://www.samsungparts.com you will need the COMPLETE model number IE: HLR5667W or HLR5667WAX to figure out which board you have and then you can order it from there as well. The board they sell has NO metal shielding around it so when you order the board you pull out your old one once you receive the new one and swap the metal shieding from old to new. ..Please take a few minutes to rate my answer...Thanks
May 19, 2010 | Samsung HL-R4667W Rear Projection...
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung Ant 1 (Air) and Ant 2 (Cable)
no ant 1 is for dtv off air siginals ant 2 is for cable chann.
Feb 04, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
I have a Samsung HL-R5667W that is about 3 1/2 years old. The screen is dark except for occasional flickers of light. The lamp appears to be giving off light when I look in the back. I replaced the bulb...
Hi my name is Eric,
I hope I can help you with your issue ,
Most likely your colorwheel is bad,
second possibility is the digital board.
Both are for a technician to install, you could do more damage poking around inside the TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Sep 26, 2009 | Samsung HL-R5667W 56" HDTV
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Samsung dlp hl-r5667w
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
Hl-r5667w
I just responded to your other post check the connection between the lamp and ballast at both ends. Also did you get the same exact lamp as your old lamp, as Samsung has two different arc gaps and they wont work if you get the other type even though they look the same physically.
Jun 21, 2008 | Samsung HL-R5677W 56" HDTV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
