Question about Fujitsu LifeBook® N6420 PC Notebook
8 beeps no operating system (sole blinking light-sroll lock)
I had the BLOD for a few times. I left the machine off for two days while I was away. Now there is nothing. Black screen, power light, 8 beeps, then blinking scroll lock green light.
Help.
  • Cambodia Feb 16, 2008
    I took out the battery, even took out the RAM and replaced them, then replaced battery and tried it. No go.
  • 35 Answers
Try this, remove the battery and wait for a few minutes before reinstalling it again. then power on your pc. Let me know if you have a same problem.
A Simple Thanks is Good Enough
Posted on Feb 16, 2008
Engine Light comes on and off. Blinks!
  • well you need TO CHECK IT AND GO TO AUTO ZONE ...
Nov 09, 2013 | 1994 GMC Yukon
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
Flashing light
What set of lights are flashing, what color are they, do they flash all together or ripple left to right one at a time? Could be a low battery, the GC is in Lock Mode, etc. If the GC is in Lock Mode push the joystick forward until it beeps and then pull it back until it beeps. Release it and the controller will sound a long beep. Charging takes many hours on these power chairs.
Apr 25, 2013 | Jet 3 Ultra Power Chair
What does it mean when the caps lock light and num lock light flash and the computer beeps?
If your cap lock light blinks on and off, and your machine is beeping at you, it means you are about to shut off for overheating. Clean out your vents, grease your fans, and see what happens. You may have intermittant fan failure, with a fan about to stop functioning, or maybe its not working at all.
May 03, 2012 | Sager Computers & Internet
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Charger system light keeps blinking
this problem is caused by a faulty alternator and or the alternator connector has been overheated from running with a low battery, how do i know this, 20 years as a Ford dealer Technician almost solely doing electrical work, saw this blinking light issue many times.
Nov 12, 2008 | 2005 Ford Lincoln Continental
Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Oct 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Fridgidaire front load washer..control lock won't shut off
I spent two days freaking out about this same problem.
I almost went out and bought a new machine because repair technician would cost so much...
The solution of pressing option and select at the same time didn't work right away...but after 2 minutes ... it did !!!!!!!!!!
Awesome. Thank you thank you to the person who posted that solution!! It actually worked!
Nov 14, 2007 | Washing Machines
Fujitsu LifeBook® N6420 PC Notebook Logo
516 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
