Question about Hotpoint HSS25GFP Side by Side Refrigerator
Kenmore Coldspot 106.7685110
Thank You for reading this;This fridge is obviously old. February 8th, I pulled it away from the wall and cleaned under and behind.(Never a problem up to then). February 13th a.m., found to be warm inside.Checked under for good Terminal (Block) connections etc., appear okay.Pull Thermostat down, and have current, Jump the 2 wire connectors that go to the Thermostat, Fridge begins to run!(I hear the compressor). Is it possible that just the Thermostat needs replacing? Ohm Meteris "Dead" across Thermostat Terminals. Thank You for any advice -Ed, Indianapolis
    Scholar:
  • 90 Answers
There should be a shot circuit or near zero ohms across the two terminals when it is warm and open circuit when at freezer temps. Either the small capilary tube has leaked all of the nitrogen out or the contacts have rusted or corroded. I would say you have found the culprit....
Posted on Feb 16, 2008
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Kenmore Coldspot - both the refrigerator and freeze suddenly stopped blowing cold.
If the fridge is running and you can hear it cycling(click, ~5 sec, click), then pull the fridge away from wall, take cardboard access panel off, 1/4" hex head, attatched to the compressor(black dome shaped bout the size of a volleyball) is a relay, take it off, if it sounds like a baby rattler when you shake it, it's bad. Check this first. If yours doesn't have this, then it has a timer. Timer might be bad. Not telling the heater when to turn off. Which is causing the fridge to not continue cooling, obviously.
Sep 30, 2010 | Kenmore 53652 / 53654 / 53659 Side by Side...
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
We have a Kenmore Coldspot Model 106 70102000 with the water and ice maker, it is now leaking inside the fridge itself and we have turned the water off to the ice maker and dispenser. What is causing the...
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Sep 11, 2009 | Kenmore Refrigerators
Kenmore coldspot 106.54563300 is not cooling. First the freezer stopped cooling then the fridge stopped. The fan is still working. Pulled fridge out, compressor was very hot. Is this a relay problem? If...
Not good news, it sounds like a compressor problem. Vacuum clean everthing you can safely get to in order to make it eaiser for the repair guy, (hopefully to save money). How old is the fridge?
Jun 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 106.63854302 Coldspot is not holding temperatures
Hi i had the same problem and someone came in it was well worth it it was the relay button and it only cost $50.00 for the part .
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Dec 05, 2007 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
116 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
