Question about Zenith ZRY-316 Video Recorder
Dvd player not working
Wont read any discs. it tries and tries but eventually ejects dvd. i have tried lens cleaner. will still read audio cds, but not dvds.
    Champion:
  • 208 Answers
This unit has separate optics to read audio and dvd's and unfortunately you are describing a defective pick up assy (lazer). This unit is not servicable and you cannot get parts for it because LG/Zenith has made these units exchange only. Your owners manual will give the # to call to get quotes and instructions for arranging exchange. I have found this is pretty reasonble for this service.
Posted on Feb 16, 2008
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
Initializing DVD
Try to clean lens eye wth a specific cleaner, and try again
Apr 14, 2008 | GoVideo Go Video DVD/VCR Combo
DVD player wont read disc.....
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load all Cd's/movies.The weak lens is what is making the player select discs, that is, not playing all discs.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's/movies with no problem at all.
Good luck.
Apr 23, 2010 | Samsung HT-Q70T System
My dvd player plays cds but wont play dvds says disc error or unknown disc
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
Every disc is a "Bad Disc".
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | Recoton Advent Advent DVD-8200 DVD Player
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Disc not being read - reading reading reading
That looks like a lens problem, when there is a fault of different kind you usually get an error message.
If you use a CD cleaner , use a good one , the $2 CD cleaners do not work, you need a kit with cleaning solution. Check here.
Run the CD cleaner a couple of times more , and see if this work.
If it does not work , the unit must be taken apart, and the lens cleaned directly with a cotton stub and cleaning solution, or isopropyl alcohol.
If the lens is defective, then the lens pick up should be replaced.
Oct 26, 2008 | Philips DVD633 DVD Player
Wont read divx on cds
I have had this same problem on my Toshiba. I went through the Control Panel and their were settings for the dvd player it used. You can change settings and they sometimes change automatically.
May 22, 2008 | Toshiba SD-K760 DVD Player
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
Plays cds but wont read dvds
upgrade the firmware on the product.
Nov 10, 2006 | Sanyo DRW-1000 DVD Recorder/VCR
Zenith ZRY-316 Video Recorder Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
