Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hey the front plastic screen has dust behind it how do you take the front off to clean it
    Genius:
  • 1,030 Answers
Remvoving the screen can be a chore there are several t20 screws thaR AttCH the screen or the front bezal that contain the plexi like screen. there is a small plasic gromit or clip at the bottom of this that makes is difficult to remove. usally u have tor remove the entire front panel and control panel. i have learn as a tech to remove by leaning the screen forward from the top then pull out getting back on even trickey
Posted on Feb 16, 2008
Cob webs behind screen
The frame around the screen just pops off. Unscrew the plastic holders from the chassis frame and the screen will come off allowing you to clean everything inside easily. The "2" thin screens are easily cleaned and put back on easily also. Don't do what I did and think the screens go into the front slot of your plastic brace, they slide easily into the wider slot. You'll also be able to clean the dust from the reflector and guns with Windex. Much better picture after wards, trust me. You would be surprised how much dust may have accumulated on the lenses.
Jan 31, 2010 | Philips Magnavox 55P9271 55" Rear...
How to remove the protective screen filter or front covers
It depends on your model but most of the time you need to pop off the plastic RIM around the screen.
Jan 10, 2010 | Philips 46PP9302 46" Rear Projection...
I have a 42inch Toshiba Rear Projection television, my son got water on the screen and it has leaked into the screen behind the flimsy plastic front screen. How can i take off the front panel to clean the...
WELL YOU MIGHT HAVE TO SEPARATE THE 2 PIECE SCREEN. CAREFULLY TRIMMING THE TAPE ALONG THE EDGES. WIPE WITH A CLEAN CLOTH IN THE DIRECTION OF THE GROVES. UP AND DOWN ON THE FRONT-LENTICULAR LENS. AND IN CONCENTRIC CIRCLES ON THE FRESNEL LENS. TAKING THE SCREEN OFF IS EASY. REMOVE THE SPEAKER GRILL AND YOU WILL SEE THE SCREWS HOLDING IT ON.
Dec 27, 2009 | Toshiba 42H81 42" Rear Projection...
Looks like dust behind front glass on phillips 46pp8621
The only way to remove the dust and or spider webs from that area is to remove the front bezel assembly and separate the protection screen, it's better to leave a svc. co. do this because the two screens behind that are very expensive. Hope this helps..
Feb 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Cleaning behind front screen.
Sorry my friend. You and I both know the answer to this. A complete disassembly and cleaning is needed. A fire hazard is a very serious event waiting to happen. Take care of this ASAP!
Ray
Nov 06, 2008 | Holmes Products HQH307 Compact Heater
Dust behind screen
take off the screen cover (the plastic) with a pin and clean it with a (magic) cloth.
Jul 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Dark blotches / Dirty behind screen
it could be dust in the mirror or in the optics,in this set if im not mistaken you have acces to the mirror from the back, anywhere from 12-20 screws it sould be easy to remove plastic cover first and the the mirror.this mirror are very delicate you dont want to leave fingr prints on it it will show just like the dust is showing right know. taking the mirror off will also give acces to the lense.
use someting soft to clean it.
hdtvman.
Dec 28, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Behind plastic screen looks to have dust on it
That front screen is what Mitsubshi calls the Diamond shield. Every set is differant but easy to do. Look carefully at the top and the bottom or the lrft and the right, fr clips that run the entire lenth of the top and the bottom or the entire lenth or the right or the left side. They bsimply snap into place. Mitsubishi says to gently insert a small screwdriverbetween the diamond shield and one end of each on of the two clips and gently pull off the clip. Good Luck
Mar 20, 2007 | Mitsubishi WS-55613 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
