Question about NorStar Meridian M7310 Phone
Caller ID Hello, I am trying to find out how to have my caller id show up on my M7310. I am looking through the norstar manual but I am not finding how. I thought it might be the phone company so I called them and they said that it is activated. Any ideas? Thanks, Kelsea
  • 2 more comments
  • Dawn1 Feb 22, 2008
    Having the exact same problem as Kelsea this week. It totally is not the "adaptor" plugged in. There is not such an item on this phone system. It is the programming of the phone. The manuals are very cryptic on programming I find. I've contacted Nortel directly waiting for an answer. Or contact your rep that sold you the phone system, which is the next step I am going to do.
  • dbl1 May 07, 2008
    my problem is showing the caller ID before the call is picked up. It only shows after I pick up the line. How would I change this? Model M7310
  • seminoleag Nov 04, 2008
    Everything is set up on my phone for caller id and it is even supposed to be activated but nothing is showing up. Maybe I need to activate this again. How do I do this?
  • ynotphone
    ynotphone May 11, 2010
    But it also depends on the software release,
    Some of the older system only can offer Caller ID to one set, even if your set rings.
    You may have to press FEATURE 8 1 1 to see the caller information.
First off seven to nine you do not use an external cid unit for norstar systems. Make sure you have a caller id card in the main ksu or key service unit( the phone cabinet) It should say CI on it. If the card says DS then you do not have a caller id card on the system and will need to exchange it for one. Then the system phones will have to be programmed for cid.
Posted on Mar 25, 2009
  • 72 Answers
Hi Kelsea
Make sure you have your power adpator pluged in for you caller id. Your caller id will automaticly show up. If your adaptor is pluged in it is on the phone companys end. all phones are preset to accept caller id weather or not you have it actived on your phone bill.
Posted on Feb 16, 2008
CANT GET CALLER ID TO WORK ON NORSTAR M7310 PHONE IS IT CAPABLE
This feature requires a class trunk card in the phone system to pass Caller ID.
Jan 17, 2013 | NorStar M7310 Corded Phone
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Caller ID
Yep. It requires a TD-193 CID card. They are kinda hard to find, but they can be had for $150-200. The last one I had got "lost" by a major shipping concern. That's tha last time I insure it for wholesale value LOL
Jul 19, 2010 | NorStar Meridian M7310 Phone
StarTalk Flash is 1.7.00 + caller ID
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Hope this helps.
Mar 24, 2010 | NorStar M7310 Corded Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Display caller id before pickup
talk to your phone service provider.
May 09, 2009 | Office Equipment & Supplies
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
How to setup caller id?
Have your tech look again. A keyword search of CALLER ID in the pdf should explain it all, especially page 158 of a 6.1 CICS manual.
You need 2 things to make it work. One is that your phone has to be ringing. Two is that Under Telco Features in programming for your set is a CALLER ID set which is No by default.
Of course, FEAT 811/812 will work after the fact.
Carl
Nov 13, 2008 | NorStar Meridian M7310 Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
NorStar Meridian M7310 Phone Logo
1,564 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
