Nextar MP-1607 Portable DVD Player
Problem for Nextar MP-1607 Portable DVD Player
Nextar dvd portable player mp007
By ticlaude41 on Feb 16, 2008
screen is black and sound is working what could be my problem
please help ............... kids player
thanks claude
Same Problem
Mar 06, 2009
-   I've got 1 for you guys- I have 2 of these units (one is the Myron Davis & the other is the Nextar) & both are displaying the same symptoms. The screen is dark but if you press the LCD/OFF button on the remote, the screen briefly appears as normal & then it goes off again. Press the button x2 again & it briefly appears & goes off. The same symptoms occur every time you repeat these steps with both units. Any ideas where I should be looking & what components to look for? I'm a tech myself & have access to most of these components & can do the repairs myself but if anyone knows something about these it would be much appreciated
thanks -   anypassword
Aug 24, 2008
-   Notre écran est noir, le son fonctionne et nous ne voyons absolument rien malgré les tests. Pouvez-vous nous recommander un technicien dans la région de montréal qui connait ce type d'appareil pour corriger le tout merci.
Nextar MP007
Sylvain
syldeslauriers@hotmail.com
-   sylvain1970
Best Solution
posted on Feb 16, 2008
Helpful)
Benimur
Rank: Guru
Rating: 88%, 3780 votes
Hi Claude,
It could be any of the three video related sub-systems:
1. Cold Cathode Florescent Lamp;
2. Inverter board; and/or
3. Video interface board.
Of the three, 1 and 2 has been known to occur more often. To verify if it's either the CCF Lamp or the inverter, pls:
a. run the unit normally albeit you can't see anything. Pop in a known good DVD disc and play.
b. shine a flashlight at an angle relative to the screen;
c. see if you can see some semblance of the video (though it may really be very dark).
If yes there is display but dark, then you have isolated the problem to either of the 2, if none then the problem is with the video interface.
Corrective procedures would require knowledge and familiarity with electronic components and circuitry, use of a DVM and possibly a soldering iron. Should you not be comfortable on a Do-it-Yourself, perhaps your best bet would be to seek the services of a qualified professional or your friendly neighborhood electronic shop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 29, 2009
Not Rated)
calvinf220
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I switched the AV switch from OUT to IN and back, a few times, and the LCD image miraculously and surprisingly returned.
Was this helpful?
Yes
No
Solution #3
posted on Jul 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey, I dont know if i have a solution, I stumbled on your posting looking for parts for my MP007. I have sound but no screen also and noticed that when I try to use a Playstation 2 on it and fidget with the AV in/out switch while in the "in" position, the picture cuts in and out. So im going to replace the switch and see if that works.
Solution #4
posted on Apr 14, 2008
Not Rated)
gmfl55
Rank: Apprentice
Rating: 0%, 0 votes
Did you check the LCD off/on button on the remote?
Was this helpful?
Yes
No
Popular Solutions for Nextar MP-1607 Portable DVD
Questions and Unsolved Problems for Nextar MP-1607 Portable DVD
Do you recommend Nextar MP-1607 Portable DVD Player?
Answer
Answer
i lost my power cord - where can i get a replacement for the nextar s3?
Answer
I plug in the headphones but the audio still comes through the speaker, not the headphones.
Answer
strap mounting brackets for nextar mp16072 7'' dual screen portable dvd player
Answer
This little DVD player has played fine for the 1 month we have had it and all of a sudden there is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nextar MP-1607 Portable DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
