Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Power does not stay on!!!
When we turn the projection tv on it starts then about 4 secondes the power shuts down and we get distinctive 3 flashes on power on light. Wont come back on till you unplug and start over?
  • selkhodary Feb 16, 2008
    I have the same exact problem, if any have a solution please help
  • tlg42 Feb 16, 2008
    Could you help me with the convergence ic part # from Panasonic? Possibly the best place to buy also?
    thanks Tim
  • Panasonic Master
  • 8,617 Answers
3 blinks in that model means convergence. change your convergence ICs and possibly the resistors located right next to them. Thats what is causing your set to go into protective mode and the blinks are a self diagnosis feature. Let me know if you need any additional info.
Posted on Feb 16, 2008
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Tv stays on but no picture and there is a click sound
quite possibly the ballast is the problem its not uncommon for the ballast to take the lamp out when it blows out. Have you tried to access the self diagnosis feature to see if there is an error code?
May 11, 2009 | Televison & Video
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv powers off after 1sec being on?
does the led flash when you try to press power after it shuts down, or when it shuts down? If so how many times does it flash?
Jul 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Power will not stay on
Sounds like its shutting down because of the b+ regulation circuit isent working and going into HI Voltage shutdown or theres a fault in the horizontal drive circuit. If your not a tech and now about serviceing the HI VOLTAGE in a tv set then PLEASE seek a service tech to assist you with this repair. Sorry i couldnt assist you more with this. Good Luck
Jun 25, 2006 | Philips 43PP9202 43" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
