Maytag washer top load
Leaving clothes wet, I guess not fully spinning them dry.
BUY A NEW WASHER
Posted on Mar 28, 2008
Same problem here for the 2nd time. if you have had a loose button or change or left anything in the pockets that can get under the spinners on the side there is something probably stuck and then that burn out the arm that attaches the drum to the washer and it cost approx 180 for the repair man to come and fix it because you have to have special tools to remove the spinners. if you find something cheeper please let me know/
Posted on Feb 18, 2008
    Genius:
  • 3,587 Answers
Good guess...is the washer balanced? That can make the spin cycle work ineffectively.
Posted on Feb 16, 2008
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
Dec 02, 2013 | Roper RAS8445KQ Top Load Washer
When there is a large load of clothes in the washer my washer does not spin fast enough to get the water out of my clothes, what is wrong with my washer?
You don't have to fill too much the washer, leave 1/4 of the cylinder free (if it's a front load washer) or check the maximum level for the top-load washer.
Be careful not to compress the clothes.
The weight that the washer can manage is the weight of the WET clothes.
More technically: the washer need to balance the drum before to spin-dry and for this it needs some free room in the drum. There is a sensor that check that there isn't too much vibrations during the spin-dry, otherwise it stops!
Sep 12, 2013 | Washing Machines
It doesn't spin dry the clothes like it use to. Although there is no water in the tub at the end of the cycle the cloths are quite wet
if the clothes are soaking wet, the tub isn't spinning. Have you stood at the machine and listened for the spin? solution may be as simple as a broken interlock switch. Let me know.
Jan 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Need help please with washer machine,wont spin my cloths,just drn
a belt has snapped or came off or the motor and brushes are damaged.
Sep 20, 2009 | Maytag MTW5700TQ Top Load Washer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
