Ford ka brakes
How do you get the rear brake drum off to check condition/ change shoes
  • badhairday Mar 02, 2008
    Thank you. It's sorted now
  • Anonymous Sep 13, 2008
    there is no srcrew on the drum r the bolts on the back of the drum.
  • 113 Answers
The most common mistake is to leave the emergency brake on. After you check that get a hammer (preferably a mallet) and slightly tap it on all four sides and that should loosen it up.
Posted on Mar 01, 2008
1998 ford escort se hand brake need adjusting. doesn't hold.
Try to adjust the rear brakes tighter at the shoes, if you have drum brakes. May require taking the drum off and adjusting the adjuster. Or, adjusting it from the backing plate access hole if there is one.
Be sure to check the cables to make sure they are not broken anywhere between the hand brake lever and the back brakes.
Good luck on this repair.
ADJUSTMENT
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the brake drum.
  4. Using a brake adjusting gauge, measure the inside diameter of the brake
    drum.
  5. Compare the brake drum measurement to the brake shoes.
  6. Adjust the brake shoes by inserting a brake adjustment tool into the knurled
    quadrant of the rear quad operating lever and adjust the shoes to the same
    measurement as the brake drum.
  7. Install the brake drum.
  8. Install the wheel and tire assembly.
  9. Lower the vehicle.
  10. Check the brake system operation by making several stops while driving
    slowly forward.
Nov 02, 2010 | 1998 Ford Escort
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    Jul 17, 2010 | 1995 Ford Contour
    97 ford f150 changed rear brake shoes but can not get rear drum to go back on over shoes, fells like something is keeping the shoes from giving so drum can go over
    Make sure the parking brake is not on, and that the brake adjuster is screw in all the way, adjust brakes after brake drum is on, from the back side on the backing plate, there will be a slot for adjustment, or you might have to knock out the tab, to be able to adjust brakes.
    Jul 16, 2010 | 1997 Ford F150 Regular Cab
    Back brake drums grinding
    Take tires off then inspect rear brake shoes if okay and not down to the metal service the drums with sand paper and put them back on you might have to replace the drums and shoes!
    Dec 24, 2009 | 1993 Ford Escort 4 Door
    I need a diagram for the rear drum brake for 2002 Ford Ranger
    Copy and paste this into your search window: 2002 ford ranger rear brake diagram
    You should see four pictures pop up, select the brake parts diagram or the brake picture.
    Sep 03, 2009 | 1993 Ford F150 SuperCab
    How to change back brakes 1999 ford windstar, back brakes are grinding, brake light on
    does it have rear disc brakes or drum brakes, if disc brakes should be changed just like the front and you might have an emergency brake shoe inside the rotor that they call a halo shoe, if it is drum brakes take off the adjusting spring and the return spring remove the brake adjuster,the the brake bar then remove the brake shoe hold down spring by holding the pin from the back and pushing and turning the spring to remove from the pin, you might have to remove the the emergency brake bar from one shoe by removing the horseshoe clip from the pin on the shoe if you have problems putting it back together look at the other side that you have not torn down yet.
    Aug 12, 2009 | 1999 Ford Windstar
    Cannot remove rear brake drums
    You need to back off the adjusters on the rear shoes to allow the worn drum to pass over the brake shoes.
    A worn drum will have a unworn drum section on its outer edge where the brake shoes don't normally rub.
    This must unworn ring must be able to pass over the brake shoes before you can get the drum off.
    Two tools should be used through the brake adjuster access hole.
    One small diameter blade screwdriver can be used to push the self adjuster lever away from the notched adjuster nut, while a second flat bladed tool is used to lever the adjuster nut, rotating it so as to back off brake shoe expander adjustment.
    Jun 16, 2009 | 1997 Ford Escort
    I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
    Drum, Rear Brake System Standard Rear Brake
    Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
    Heavy Duty Rear Brake
    Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
    The rear drum brakes:
    • Have internal shoes that expand against the brake drum (1126).
    • Are a single-anchor type.
    • Are actuated by one rear wheel cylinder (2262).
    • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
    • Adjust rear brake shoes and linings (2200) automatically.
    • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
    When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
    The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
    Apr 04, 2009 | 1997 Ford F150 Regular Cab
    REAR BRAKES
    i think your aware of how to change the brakes if im right and your problem is the rusted drum doesnt want to come off the only way to get the old drum off is to remove adjuster plug from behind drum dustshield and adjust the shoes so that there not even close to the braking area of the drum then try and wiggle the drum off of the assembly if it is not coming off then you need to use the old nylon hammer on the drum and i mean you must hit the drum from side to side trying by hand to wiggle the drum off its a tight fit and you need to strike the drum on the face not on the fins not wanting to damage with persistance and care and patience you will eventually be able to remove the drum to service brakes take care and good luck with it
    Jul 01, 2008 | 2007 Dodge Caliber SXT Sport Hatchback
    Computers & Internet Logo
    279 people viewed this question
    David Payne
    David Payne
