Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Can't change monitor display settings
I have a dell dimension 3000 with a dell monitor model 1704fpt. I recently had to install a new hard drive and reload windows xp. When monitor came on everything was to large for the screen so I tried to change the display settings. Could not get it to change from the 640 mode. I tried install with the monitor disk, That did not work. I then went and downloaded a driver for the monitor and install it. That did not work. My computer does not recongize my monitor. It just says default monitor. I read something on the internet that says when the dell computer comes from the factory it has a *inf file installed on it telling the computer about it. But if you have to install or reinstall xp it deletes that. Does this make any sense, can someone tell me how to fix this problem. Where can I get this inf file.
  • 1 more comment
  • Lucky51 Feb 16, 2008
    additional information about my monitor.
    I went to the dell web site to download the driver for my dell monitor 1704fpt. After downloading it I went back to their web site again and checked compatibilty list. There I discovered that my Dimension 3000 is not on the list. Tell me when I bought this computer as a package deal why would'nt they make the monitor driver compatible with it.
    Thank you Dennis, my problem is solved.
  • azharimh Aug 22, 2008
    i have installed a new version of windows xp, the monitor resiluiton and color neet setting ,all my attembts to do that had been failed help me to solve this problem.
  • 58 Answers
No drivers are needed for monitor. Its the video card drivers that you should look for at the dell drivers and downloads website. make sure that you have the right driver installed so that you may be increase your screen resolution.You may also use your Dell Resource CD Drivers and utilities. Install the Resource cd, On the TOPICS dropdown box, select drivers,You'll know which drivers needs to be installed because they will have a check mark infront of the correct device driver. Clicke extract button after you have chosen the video driver. You may need to scroll down.Restart the computer.
Posted on Feb 16, 2008
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Attempted to install New 320G hard drive in a Dell Dimension 3000, but the BIOs refused to see the drive at all. Despite double checking jumper settings and using other cables. The OS is Windows XP SP2,...
Check to see which bios version your computer is using. An update is probably necessary in order for the computer to detect the drive correctly.
If that doesn't work most hard drive manufacturers have software that you can install so that the bios will detect the drive correctly.
What's the make and model of the new drive?
Mar 09, 2009 | Dell Dimension 3000® Pentium® 4...
The display adjustment issue is most likely to not having the correct display adapter drivers installed. The admin issue though is puzzling. Have you tried creating a new user account and assigning Admin rights? What was the reason for the reinstall? It could be file corruption causing Windows to interpret the file access problem.
Nov 02, 2008 | Dell Dimension 3000® Pentium® 4...
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
New Hard Drive Dell Dimension 3000
Theres a problem with your driver installation.your computer is newly formated and wiyh a new harddrive but still theres a problem.check your monitor if it can support up 1024/768 pixel so that you can adjust your screen resolution to a smaller icons.also check your vga.and rollback device driver for sound device.
May 29, 2008 | Dell Dimension 3000 PC Desktop
Reinstalling windows on new hard drive
Place the windows cd in the drive and re-boot.You should be prompted to press any key to boot from the cd.After that,just follow the on-screen instructions.It's really pretty simple!Hope this helps!
Feb 20, 2008 | Dell Dimension 3000 PC Desktop
DELL DIMENSION 2350
the problem can be from  the video card or from  the monitor.for the monitor go to the officila dell site..there you can  find all the drivers you need..and for the video card instal a new propper driver..
if all this doesnt work..well contact a specialized Dell service..
bye
Feb 03, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
2,882 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
