Question about Avaya 2410 Corded Phone
Pick up call from another station without a group
Is it possible via a default feature code to pick up an incoming call from another adjacent phone without programming a group. Example, you are in the area, within ear shot of the ringing phone and want to pick up the call at the phone you are nearest to. Is it possible?
Thanks, Mark
What system is this phone on?
Posted on Jun 13, 2008
We are not able to pick up incoming calls the phone message states "make calls first"???
It might be that your pick up key is mislabeled/programmed. Press feature * 0 then the pick up key to identify what the feature is on the button. If it's not pick up, exit out of button inquiry press feature * 3 the button you want to program (pick up) then press feature 75 That will program it as a group pick up key
Apr 28, 2014 | Nortel Meridian M7208 Corded Phone
I can only pick up when it rings from the main phone. panasonic kx-t7633
These systems have manuals for a reason. The unprogrammed system has no ICD group assignments. When you put the phones and the ring preferences into the groups, the phones will both blink and/or ring on incoming calls. By default ICD group 1 is 600.
Carl
Jan 28, 2011 | Panasonic KX-T7633 Corded Phone
I should be able to use Feature 75 to pick up an incoming call; however, when I try the phone tells me that it is denied in admin. How do I fix this?
more than likely your not in the same pick up group as the phone that is ringing. Instead of setting up pick up groups you could use feature 76 (directed pick up) if you know which set is ringing.
Apr 08, 2010 | Nortel T7316E 2-Line Corded Phone
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Mar 09, 2009 | Panasonic KX-T7630 Corded Phone
Be able to pick up incoming calls from all front office phone sta
Get a copy of the manual here
http://www.cactcom.com/Manuals/Vodavi/Vodavi%20DHS/Vodavi%20Starplus%20DHS%20Installation%20And%20Maint%201995.PDF
Looks like you can group the stations together and then any one of them can answer incoming calls. See page 45 or so.
Jan 22, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
How do you answer another phone in the office by using your own phone
Ascertain from your system administrator the directed call pickup feature access code, this will allow you to pickup any ringing call as long as you know what ext number is ringing.
Jul 11, 2008 | Mitel 5220 IP Phone
PICK UP GROUPS AND HUNT GROUPS
You will need to talk to the phone administrator. It needs to be set up in system admin.
Nov 08, 2007 | Avaya Definity 6408D Corded Phone
Lands Phones Logo
110 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
