Question about HP LaserJet 1320 Printer
Problem with HP 1320
My hp 1320 only print in paper from tray 1 (upper tray ) and I
cant print in papers which are in lower tray
  • 1 more comment
  • mubarak1983 Sep 12, 2008
    The lower tray has a metal plate which carries the papers, it does not lower into place when pushing the tray to close, I have to push it down to with a pen then close the tray.
    On performing print operation, the printer doesn't pick papers from the bottom tray.
    Also the hazard light keeps flashing on & off. Nothing wrong with the toner though, quality is OK. The toner has logged printing 4000 sheets already.
    Any help is appreciated.
  • Anonymous Sep 26, 2008
    I have the same problem. It seems that no matter what I do (change setting, reload drivers, etc.) my printer will not print from anywhere but Tray 1.
  • Anonymous Jan 27, 2009
    I have the same problem - I change all setting to tray 2 but it still want to print to tray 1 - manual feed.
Techguru, Tray 2 relay??
Where can that one be accessed from, is it an invasive procedure??
Posted on Sep 12, 2008
  • 28 Answers
Ok Solution for that is (1) Ch3eck for the Tray 2 relay .. It is not working
Posted on Feb 22, 2008
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Mar 28, 2013 | HP LaserJet 1320 Printer
Can i disable try 1 on this printer
Usually the paper source is set to Auto in Printing Preferences so if you put paper in manual tray it will feed from manual tray and will override the tray 1 selection. If you specifically want to change it to a tray disabling tray 1 you can do so if you go into Control Panel, Printer and right click on the printer and select Printing Preferences and then on Paper menu change the paper source.
Feb 10, 2011 | HP LaserJet 1320 Printer
My HP LaserJet 1320 is showing an Orange Light ( Exclamation mark inside the Triangle) and i could not make any printing... It's keep showing that problem after restart the Printer. Can anyone give me some...
if the light is blinking it means
1. either the cartridge door is open
2. or paper tray is empty
3 or paper is misfeed
4. or paper jam
Verify that the print
cartridge is present and
that the print-cartridge
door is closed correctly.
2. Verify that media is
present in the input tray.
3. Clear any jams and
perform paper-path
functional checks.
4. Make sure that the
interlocks are operating
correctly.
Jan 12, 2011 | HP LaserJet 1320 Printer
My printer chew one side of paper laserjet 1320
Is the correct model number: HP Deskjet D1320 Printer ? Was printer working properly at one point? May be resulting from failure to fully clear a paper jam:
Paper jam
To clear a paper jam
1. Remove the paper from the paper tray.
2. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
3. Turn off the printer.
4. Remove the rear access door. Press the handle to the right, and then pull out the door.
5. Remove the paper jam from the back of the printer, and then replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Caution Remove the paper jam carefully as it is possible to damage the printer when removing paper from the front.
7. Reload paper in the paper tray.
8. Turn on the printer.
9. Reprint the document
if this does not help I would suggest installing a new driver from: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ca&docname=c00211293&product=1839853&
Trust this is helpful. :)
Dec 08, 2010 | HP LaserJet 1320 Printer
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
My 2003 laser jet 1320 suddenly quit printing.
Good chance something is wrong with the tray, are you able to print of you place paper in the multi-purpose tray (tray 1)?
If so, one thing that may be your problem in tray 2 is here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974
Feb 28, 2009 | HP LaserJet 1320 Printer
Paper light won't turn off
Tryloading paper in tray 1 / bypass assembly. Pull down the black tab under the HP logo
Feb 20, 2009 | HP LaserJet 1320 Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP LaserJet 1320 Printer Logo
306 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
