Question about Panasonic CT-36SL13 32" TV
How do you reset the Panasonic TX-32LX700M LCD TV?
After the TV trips out how do you reset it? I understand it must be done via the remote, and possibly the TV as well. Thanks.
How do you reset the Panasonic CT-36SL13 32" TV?
  • puff2003 Apr 03, 2008
    My CT-32SL13 TV was hit by lightening, since then TV went dead.
    I was told I have to replace the main power supply. Where I can get one?
  • lars ahlsen May 11, 2010
    Hello..what do you mean "trips out" ....pse advise...Ron
jomaru
  • 337 Answers
SOURCE: Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Posted on Sep 27, 2006
maklean
  • 1665 Answers
SOURCE: TV does not power up
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
Posted on Feb 14, 2008
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
  • 17 Answers
SOURCE: Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Posted on Jul 15, 2009
dave1645
  • 834 Answers
SOURCE: I have a panasonic 32'' hdtv that may need a thermistor
there is a diode gone bad in the power supply have a tech come out and replace it
Posted on Nov 24, 2009
How do l get into the panasonic Tx39in a300b hidden service menu
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Panasonic Televison & Video
I want to know the service menu code of Panasonic TX-32LX70C
Oct 08, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Tv remote doesnt work
Programming a universal remote does not change any settings for the TV. If the original remote is not working you may want to try changing the batteries. If this does not help, the remote itself may be bad.
Apr 09, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a Panasonic Viera 32" LCD-TV TX-32LX70 TV and the volume suddenly goes load and after a while it returns to norrmal. any one have any ideas/ thank you
Well it could be the sound amplifier or a cold solder joint on the sound amplifier , Does the remote have any effect? or the buttons on the front? It also could be the jack in the rear to the tuner is loose, the cable.
Jun 30, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic TX-l32XT - I hit a button on the remote, don't know which one, and now I have no signal.
Without knowing much more, chances are it is a multiple use remote and you hit a button telling it to control another piece of equipment. If there is a "tv" or "home" button, hit that. If not, I would remove the batteries and put them back in. That should reset it to the default of the tv.
Hope this helps
Jan 28, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: http://www.retrevo.com/support/Panasonic-TX-32LX70-TVs-manual/id/2920dj480/t/2/ if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Display
press and hold down the i button on the remote and the screen program number will disappear
Apr 10, 2007 | Panasonic TX-26LXD1 26 in. LCD Television
Panasonic CT-36SL13 32" TV Logo
131 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
