Question about RCA D61W136D 61 in. TV/DVD Combo
Dvd the dvd will not open with a dvd inside
If there is any pin point holes around or on the disk tray then take a push pin and push in the hole the tray should manualy pop open. from there you would have to pull the tray completely open. if not. it could be a faulty motor. in which case you will have to get the tv or dvd player replaced. not worth fixing if it is under warrenty. if not. you are better off letting go and moving on.
Posted on Jul 13, 2009
DVD player not working!
The player uses a laser to check for a DVD. If the laser fails, the player acts like there is no DVD loaded and opens the disc tray so a DVD can be inserted. Sounds like a bad laser.
May 04, 2015 | Televison & Video
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
I kept a disk in a dvd writer and after sometime it has broken in the writer i have removed the disk tray and removed the broken disk pieces now the tray is not going inside
You need to open the cover of you DVD driver to check if there is some particle left inside the DVD. As there is a possibility that there is something left inside the DVD. If you have idea you can open it and remove everything left inside the DVD.
Apr 26, 2011 | Samsung (SH-S162L/BEBN) DVD RW Burner
DVD disk is not going inside the dvd driver in my dell vostro 1510. Could you please tell my why my disk is not going inside the dvd driver?.since driver is inbuild i unable to open the driver.
try opening a media player preferably windows media player and try ejecting from the play tab.
if it still doesn't work, check to ensure the driver is working
Jul 17, 2010 | Dell Vostro 1510 Laptop
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
My Toshiba ts-h653 cd/dvd RW drive failed w/DVD inside
ur desktop needs to be open at all cost otherwise no solution
Nov 30, 2017 | Computers & Internet
DVD player won't open. DVD inside
On my DVD player, the cover on the disk tray was setting too high. I removed the cover, cleaned the glue off and reset it. This time it was flush with the tray. It now opens and closes just fine.
Another possible solution is to unplug and replug-in player. You still may have to do this after using my first solution.
Note: My DVD player also starts showing "hello"
Note: This solution was also listed under "dvd wont work"
Sep 23, 2009 | Televison & Video
Won't open and have dvd inside
well if they both dont open its due to the players little gears there either jammed,boken,or just plane need replacing try opening the player and moving the tray with your hands back and forth and try losening the little gears its should work
Apr 15, 2009 | Philips Dvd Video Player
CD/DVD
see care fully on the cd/dvd door, there must be a very narrow hole. This is an emergency hole to open the door.
  1. Make shutdown your Lap.
  2. Take a long niddle or hard wire.
  3. Push it gently inside the hole.
  4. It will strick inside, then push with slightly more force and you will notice that door is openning. Just push more till you can pull out CD/DVD tray by hand.
Thanks
Iqbal
Apr 28, 2008 | Dell Open Box 8300-6SZ0X41 P4-2.8G 256M...
RCA D61W136D 61 in. TV/DVD Combo Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
