Question about Adesso PCK-308UB (DHPCK308UB) Keyboard
Seemingly loose keyboard connection
PCK-308UB keyboard functions only intermittently, only when I jiggle the USB cord near where it enters the keyboard. I opened the keyboard and didn't see any obvious loose connections.
  • 583 Answers
Probably a broken wire within the cable itself. If you want to try to salvage the keyboard and it is not under warranty, then you can cut the cord about two inches from where it enters the keyboard, strip the wires and connect them where the old connections were. This will require a bit of dexterity in order to accomplish though.
Posted on Jan 26, 2010
SOURCE:
Why is my microwave dead?
Assuming you checked the main fuse (inside the case, near where the power cord enters), you might have a bad connection to the (main fuse) fuse holder. Sometimes these heat up and oxidize. Some thermal protectors operate seemingly backwards; in that they are normally open, and close when certain conditions occur (such as a fire in the cavity). Make sure all door switches actually function properly by checking them with an ohm meter. Although extremely rare, power cords sometimes fail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 09, 2014 | Microwave Ovens
Can't get mouse pad working
If the rest of the keyboard is working i would be inclined to think there is damage to the cable that connects the mouse pad to the rest of the keyboard.
Oct 22, 2013 | Adesso PCK-308UB (DHPCK308UB) Keyboard
The keyboard seems to have lost function of some keys is there a reset just to take the keyboard back to its original settings
There is no reset. Go to the device manager and remove the keyboard and then scan for changes or re install keyboard driver and or software.
Tom Miller
Broadcast Eng
Sep 08, 2011 | Adesso PCK-208B Keyboard
I'm trying to sync an apple ipod shuffle 4th generation to my windows xp pc. The famous USB device not recognized thing pops up. What do i need to do so i can use and sync my ipod.
Shutdown Windows.
Turn the computer off.
Unplug the AC power cord.
Reconnect the AC power cord.
Restart the PC.
This will eliminate many "intermittent" problems.
Now, connect some other USB device (mouse? keyboard? memory-stick?) into the USB port, to confirm that the USB port is working, at least for some USB device.
Now, connect the iPod to one of the USB ports.
If it is not recognized, connect the iPod to a different USB port.
This should work.
Jun 01, 2011 | Computers & Internet
Number,one,three,five seven and zero not working and back space aswell
Is your keyboard connected via USB (a flat rectangular connector), PS/2 (A round connector, often it is purple), or AT connector (a round connector that is roughly twice the size as the PS/2 port for your mouse)? More than likely, it's connected via USB. Especially if it was bought within the last five or six years. If it is a USB keyboard, try plugging it into a different USB port and see if that helps. If that doesn't help then most likely the cord on your keyboard is damaged (kind of like when you have a pair of headphones that will only sound on one ear unless you jiggle the wire). If it's not the USB port (or you have a PS/2 keyboard) I would recommend you buy a new one. You can get one for as cheap as $10.
USB Connector: crasher35_6.jpg
PS/2 Connector: crasher35_7.jpg
AT Connector: crasher35_8.jpg
May 29, 2011 | Computers & Internet
Vacuum is turning on and off intermittently
Turn the vacuum ON.
Go to the plug while it is in the outlet, jiggle it and the wire going into it to see if there is a loose connection on that end.
Then go to where the wire enters the vacuum.
Jiggle that to see if that makes the vacuum stop.
If there are no problems found on either end of the wire, the next step it to open the machine and check the connections at the internal switch and the switch itself.
Let us know.
Gary
Jan 29, 2011 | Hoover Breathe Easy U5250-930 Bagged...
My husband has an HP computer and is using windowsXP. Suddenly, he cannot enter any typed infomation as required during a search, but his cursor works to go to the blank field. He cannot type into the...
Your keyboard USB cord has probably become loose. Try reseating the cable into another USB port, or just reseating it if the keyboard uses a keyboard cord.
If this doesn't work, try a different keyboard (if you have another one around the house).
You may have either a bad USB port, dirty port, or bad keyboard.
please rate my solution!
Jul 17, 2010 | HP Pavillion s7420n PC Desktop
What is the function of anti virus? and difference between antivirus and firewall
Antivirus software is used to discover and remove computer viruses.
Firewall software is used to control network (internet) traffic to and from a computer which helps block invasion (hackers).
Feb 26, 2009 | Adesso PCK-308B (DHPCK308B) Keyboard,...
Adesso PCK-308UB (DHPCK308UB) Keyboard Logo
Top Adesso Computers & Internet Experts
mark
mark
Alun Cox
Robert Salgado
Robert Salgado
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
