Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Samsung b1445 washer
By booyakka on Feb 15, 2008
washing machine wont start just get a humming sound
the model is a samsung b1445, we did have a error report of
5E. the manual suggested cleaning the debris filter out, which we did but now we just get the humming sound
Comments:
Feb 16, 2008
- it is a front loader and the error code was Five E
Feb 17, 2008
- i eventually took the pump off and gave it a good clean, put it all back together and it now works fine , thanks for your help
Clarification Request
Posted by tech17 on Feb 16, 2008
is this a front loader or top loader and is the code se or 5e
Solution #1
posted on Feb 16, 2008
Somewhat Helpful)
tech17
Rank: Guru
Rating: 88%, 1531 votes
let me do a little research can you turn the drum by hand to make sure nothing is jamming it
Comments:
Feb 16, 2008
- shut the door make sure the dispenser door is closed turn it to spin see if it starts and see if the door lock light comes on
Feb 17, 2008
- i thought you said you already cleaned the pump
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
priyabrat
Rank: Wiz
Rating: 77%, 166 votes
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
how can i fix my washer bellow by myself model #mfw9600sq0
Answer
manual for westinghouse washing machine lt959s
Answer
Washer leaks all out the front door. Tried cleaning rubber around the door, and still no luck. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
