Question about Sherwood AVR-525 Receiver
Sherwood AVR 525 Receiver
I have lost the mains power cable to the receiver (UK). Can I get a replacement anywhere?
  • 1,512 Answers
If it is just a 2 pin "figure of 8" type plug(shaver plug) they are available most any electronics hobby shop, or an appliance retailer. If you have trouble identifying the socket on the amp... get back to me here. Good luck:)
regards
Graeme
Posted on Feb 16, 2008
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
I have lost video on my tv - connected via hdmi to denon avr-689 receiver.
Had a similar issue, replaced the receiver three times in first month. The fourth time it had to go back to Denon. They returned it saying no fault. Also replaced HDMI cables etc...real head scratcher. Turns out it was the tv. The system can get discombobulated if the receiver, tv and source are not sequenced correctly. This is due to the HDMI protocol, Power up sequence should be receiver, source tv. Once video is lost it has to be rest. With system powered up and tv displaying no signal, remove HDMI cable at tv. Turn off tv at outlet and leave of for 2 minutes (this rests HDMI port, important to leave off long enough!.). Turn tv on and reconnect HDMi...all should be good. Poor Denon, I blamed them when it was my Sony Braiva all along....bad Sony
Apr 16, 2011 | Denon AVR-689 Receiver
No sound . pleased send the location of servicer center for sherwood avr
Go to...
http://www.sherwoodusa.com/service/index.php
Input your zip code, and within miles.
Feb 28, 2011 | Sherwood AVR-525 Receiver
Volume control
you will need to take it in for service your volume control is going out eventually if it does you will not be able to turn the sound down at all or even adjust it
Nov 02, 2009 | Harman Kardon AVR 525 Receiver
Memory troubleshooting on sherwood RV 5080 R
Hi Francois,
i own the same receiver with the same problem, but solved it according the following (german language) instuction with photos:
http://ekkart.de/rauhesitten/?p=198
I changed the broken capacitor against a gold cap.
regards, Bernd
Aug 24, 2009 | Sherwood AVR-525 Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
Sherwood R 525 memory loss
Same thing happened on my R-925RDS. The memory backup capacitor in this case is C322 on the front panel PCB, over on the far left hand side by the mains power button.
In the case of the 925 it's a 0.047F 5.5V capacitor, a small black block approx. 10mm high with 10x5mm footprint. In the service manual it's referred to as 0.047uF, but this is incorrect. Replaced it with a 0.1F 5.5V memory back up capacitor, all's well.
If replacing the capacitor, BE CAREFUL where you mount it! Putting a standard (round) backup capacitor in the exact location of the old one may bring it very close to the mains switch. What I did instead was mount mine about 2 inches closer to the centre of the board, using double-sided tape, and ran wires back to its connection points.
Nov 01, 2008 | Sherwood AVR-525 Receiver
Sherwood rx4103
i have the same problem with mine... its anoying is there like a reset on this item?
Apr 03, 2006 | Sherwood RX-4103 Receiver
Sherwood AVR-525 Receiver Logo
89 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
