Question about SanDisk Sansa e250 MP3 Player
SANSA e200 2 GB
When connecting to to my laptop it never displays a device...when I disconnect a message appears on mp3 player, could not load MusicDB remove 6 mb. Laptop won't see device how can you delete music?
  • 69 Answers
Change usb mode settings\usb mode \ mtp or mtc or what they are called i dont remember try both
Posted on Feb 16, 2008
Why is my Sansa saying 'Not enhough space for MusicDB' and all my music is gone
youve got corrupted files on the music db and must format Turn off the Sansa then hold the center button while connecting it to the computer. The Sansa should now be recognized as a Removable storage device under My Computer/Computer. Right click on it and select Format. hope this helps Kidromulous
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
How to unlock sansa 1 gb mp
Sansa Connect No-Wifi Recovery Tool
Make sure your Sansa Connect player is charged and the HOLD switch is in the unlocked position. Press and hold the power button for 20 seconds, then release it. This will force the Sansa connect player to reset and restart.
If your player still will not start after trying the reset, you may need to run the Sansa Connect Recovery application.
With a copy of the Sansa Connect Recovery application installed on a PC, you can connect your to the device via the USB cable to the PC, and restore the device software to an uncorrupted state.
However, all of your subscription settings and content will be removed from the device.
STEP 1 - Download and install the recovery tool.
STEP 2 - Put your Sansa Connect player in Recovery Mode
1. Press and hold the Power button for approximately 8 seconds to turn off the player.
2. While holding down the Right button, and Volume Up Button,
press-and-release the Power button. Keep holding the Right and Volume Up button. After a few seconds, the player will start and a Recovery Needed message will on the player's screen.
3. Connect the player to a PC.
4. A SanDisk Device Recovery dialog box will appear on your PC. Choose Recover Sansa Device and click OK.
5. Follow the steps in the SanDisk Device Recovery application.
Hope this will help you.
Jan 02, 2010 | Audio Players & Recorders
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Downloading music to my MP3 player, how do I do it. I have the music on my computer and I move to the MP3 player but when I disconnect it does not display on my MP3 player
For transfers to Sansa Clip see page 11 of the pdf manual [page 9]:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When using the drag and drop method in Windows
music has to be dropped in the Music folder of the player.
Using Windows Media Player 11:
In Library or Sync mode:
1. Create a playlist e.g. "MyPlaylist"
2. Put music in the playlist
3. Save the playlist
In Sync mode and the player having connection:
4. Move the playlist e.g. "MyPlaylist" under / to the device
5. Start synchronizing with Start Sync
6. Wait until al files have been transferred:
a message appears when you can disconnect .
When you need more help just post a comment.
Sep 23, 2009 | SanDisk Sansa Clip MP3 Player
MusicDB please free 6 MB
u need to format the player....simple as that....
Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
I was updating my Sansa e250 player while connected to my computer (windows xp), and then when I disconnected it (using the "safely disconnect hardware button), the usual message appeared on the Sansa --...
You will need to get your player into Recover mode.
1) Move "Hold Switch" to "Hold"
2) Press REC switch and power on switch untill the display shows "Recover Mode"
3) Then connect your player to your PC. The player should now show up as a removable drive.
4) Open "Notepad" on your PC and save an empty file named sansa.fmt on that removable drive.
5) Safely remove the drive and move "hold" switch to "No-Hold"
6) The display should say something like "formatting"
7) Then your Sansa will restart in MTP mode.
May 14, 2009 | SanDisk Sansa e250 MP3 Player
Can not down load voice recording to computer: Sansa 280.
You can try few simple steps like changing the USB ports, turning off & turning on the mp3 player and then reconnecting it, and then changing the USB mode on device: Menu --> Settings --> USB mode: MSC or MTP
If these don't work, try the steps here: Sansa e250 Not Detected in PC
Feb 01, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Computer won't read mp3 player
press the + for a couple sec then it a wizurd should pop that should work
Sep 27, 2008 | SanDisk Sansa MP3 Player
SanDisk Sansa e250 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
