Getting the washing machine level...
The back feet on the washing machine float up and down and I can't get the machine level so that it doesn't shake itself silly. Is there something I'm missing. I could get the feet to stay setended so the machine would be level and putting a board under it doesn't help.
  • papadoc555 Feb 15, 2008
    I tried his advice and it didn't work. the frint feet won't adjust (as far as I can see) and the back feet floats and does no good as to the level and the machine shakes real bad while spinning. What am i missing. I used the level like the gentleman said.
    Genius:
  • 3,587 Answers
Use a level(like the carpenters do) and then balance it both left to right, and front to back(both sides) that should do it. Front feet should adjust, as well, methinks.
Posted on Feb 15, 2008
  • Patrick Michaels
    Patrick Michaels Feb 16, 2008
    then, you will have to lift the entire machine up on two by fours and do it with shims..
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
My washing machine shakes during spin mode
The machine must be level or it will shake. There should be feet under the front which screw in and out. Get a spirit level and adjust the feet so it is sitting level front to rear and side to side.
Also make sure it isn't rocking slightly when it's not running - if so screw out one of the feet till it's steady. If you don't have a spirit (bubble) level compare how vertical the sides are to the wall/cupboards etc. However a level is best as even a little lean can make it shudder.
Or your putting too much washing in it!
Feb 07, 2013 | Whirlpool Washing Machines
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Washer is out of balance in the dpin cycle since we installed a new floating floor in our laundry room. Have tried rubber feet for levelers and sticky pads to floor, nothing seems to help.
So, is the machine level and STABLE? The final step is to tilt the machine forward on to the two front feet. This allows the rear, SELF LEVELING legs to reset. Then set the machine back on all four feet.
Sometimes the real feet get jambed and will not release unless you pry them loose. In extreme cases the rear feet damage the plastic holder that they are in...
BUT, the tilt foreward and set back on rear legs works most every time.
May 01, 2011 | Washing Machines
Excessive shaking and vibration when wash cycle is running
Hello, Well if the machine is vibrating it is most likely because the feet on the bottom of the washer are not locked and are screwing themselves back up into the machine. If you have someone help you can slightly tip the washer up and adjust these feet by simply turning them to adjust them down or up. This can take a few adjustments to get the machine level. take a carpenters level and set it on the washer first from the front to back on one side of the washer and adjust the feet so it is level front to back. Then take the level and set it over the control panel to level it side to side(it will take a few times to get them all even and level). when the machine is level you will have to lock the feet by turning the nut that is on the leg up to the bottom of the washer and tighten them down to lock the legs so that they do not work themselves loose again. That should stop the vibration. Good luck and I hope that solves it!
Dec 09, 2010 | Kenmore 43142 Front Load Washer
Washer is shaking around when washing it moves around about 6 inches every wash
You will need to adjust the feet on the bottom of the Washer so that they sit level on the ground. If you lift up the ends of the Washer you can either screw the feet in or out to level the Washer, and then tighten the nut down on the feet to keep it tightened.
Aug 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will not stop shaking during spin cycles, we have removed akll shipping bolts
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Jan 26, 2010 | LG Washing Machines
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
My Maytag top loading washing machine mdl#LA412 shakes violently on spin cycle with no clothes in it, a mechanic leveled the feet but it still vibrates bad. Any suggestions please!!
The ground under one of the feet may have collapsed.
The drum may be loose.
One of the springs that support the drum may have broken.
Check the machine by just trying to wobble it on it's feet, this way you can tell if it is firmly on the floor. check that the machine is level
Look down on the drum against the body and see if it is central to the frame and just get hold of the rim and try to give the drum a shake and see if it is loose, these machines always shake a bit because of the design, they are normally used in nursing homes etc in the uk
Feb 04, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
