Question about Refrigerators
Thermal switch disfunction
Our ref seldom out of coldness and does not freeze . the first time did happened we're able to restore it by unplugging the power source for few minutes then replug it. this time it happened again but our previous solution failed. why?
    Scholar:
  • 90 Answers
How long did it work before quitting? how long did you have it turned off? Does the compressor run? Many things can cause this problem..Is the back wall of the freezer cold? Are all fans running? let me know....
Posted on Feb 16, 2008
Accidentally unplugged my upright frigidaire temp light on and not freezing
If compressor is running, have you given it enough time to recover? or you may have a faulty thermal protector on the compressor. Cold control setting on right position?
Dec 23, 2017 | Frigidaire Freezers
My ice dispenser keep shooting out ice after I moved glass away. The ice comes out in handfuls.
Sounds like there is still ice in the Shute, the unit is design to clear the shute so ice want freeze in the shute. Just touch and allow the shute to clear. The shute doesn't get as cold as the rest is why this happens. There is a micro switch near the handle that might be sticking, but seldom does.
Jan 03, 2015 | LG LFX25960 Bottom Freezer French Door...
Ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then test the defrost thermostat thats clipped onto the same coil near the top of the coil,note,the defrost thermostat needs to be below 15 degrees to check good as its a thermal switch,then if still problems then check the main board in the back of the unit behind a panel this is where the defrost circuit gets its power,but i will likely say its the heater thats open because i replace about 5 per week with the same issue as yours
May 22, 2012 | GE Refrigerators
The fridge freezer does not seem to shut down. I unplugged it last time it happened and the next day i cleaned the coils under the unit and it worked great. Now 3 months later it is doing the same...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 24, 2011 | Kenmore Refrigerators
Kelvinator 401 Impression series. Oldie but a goodie until I switched it off for 6 weeks while on holidays. Switched it back on and now fridge area freezing. Tried switching up overnight (8-10) hrs and...
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it.
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Kelvinator Refrigerators
At work one of our units gets too cold in the fridge and the tenant says it freezes her eggs.Do I need a new t stat?
if the eggs are placed directly where the cold air from the freezer enters the refirigerator section, they would freeze. The temp of air coming into the ref. sect. is about 12 degrees, by the time it fills the ref. section it is around 38 degrees. try moving the eggs to a middle shelf (just not on the top shelf), If that doesn't work then I would replace the thermostat.
Mar 05, 2011 | Whirlpool ET1MHKXM Top Freezer...
Either chanell cuts out randomly. It is not over heating, and does'nt happen all the time. Otherwise sounds great. Marantz 2230. thanks in advance. Steve
Intermittent problems are no fun to troubleshoot because you have to force it to fail or wait for it to show the problem. It sounds like it could be a thermal problem or a cold solder connection. Do you hear the sound through the headphone jack on the receiver when the speakers blank out? If so your pre amp section is working, and it is in the power amp section. If not I would first use a spray contact cleaner on the switches and rheostats. Click on the link below for Cleaner.
http://www.mcmelectronics.com/product/200-150
Second, wait until the unit exhibits the problem then use a freeze spray selectively spraying parts of the board and components until the sound returns. You can use a heat gun sparingly to heat parts of the circuit to try to force it to fail. If you selectively freeze spray the board and sound returns you need to inspect the board for broken traces and touch up solder connections, which could be cold and faulty. If you spray a component and the sound is restored it could be a bad component, and it should be inspected. Click on the link below for freeze spray.
http://electronics.mcmelectronics.com/search?af=&w=freeze+spray
Jul 21, 2010 | Marantz 2230
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side
Sounds like the evap is frost up ,ice buildup.Make sure the ref. falls in defrost.If it does the problem could be faulty thermal disc or defrost heater.When the ice build up you will have no air flow and the ref side will be warm.
Oct 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
