Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
IW712- fisher paykel intuitive eco.
Machine FAULT CODE 136- Machine will not wash or spin...
  • 5 more comments
  • Anonymous Apr 05, 2008
    Our m/c stops spinning, beeps continuously & displays error 136, it will reset OK if turned off & on. This problem comes & goes but is there most of the time
    Thanks,
    Neil
  • Buzz56 Apr 12, 2008
    My Fisher and Paykel also has fault code 136.
    Called a F and P technician, he said he has never heard of that error code nor could he contact anybody who had.
    Does anybody out there have a solution???
  • Anonymous May 04, 2009
    i get the 136 fault usually when doing a smaller load. I turn it off then on again and adjust to the next rinse cycle to continue.
  • Anonymous Mar 17, 2014
    My F & P Intuitive Eco IWM10 can be turned on but keeps saying "filling" but there's no water sound. We checked the hose and we checked for blockage but there is no evidence of it. We tried to spin but it doesn't do it either. it used to tell us the fault code but not now.
  • Anonymous Mar 21, 2014
    How do I remove the lid ?
  • Anonymous Mar 29, 2014
    fault 37 using binary code is showing ,I have excessive soap suds .after washing is finished which takes longer then normal .Fault 37 is up . So far I have cleaned the exit hose cleaned the pump out cleaned bowl , Please help how looking at levle control or board .
  • Anonymous Mar 30, 2014
    what is fault 234 on a fisher & paykel washing machine?
  • 92 Answers
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel intuitive Fault code 136
Sounds like a motor problem Check the motor harness,connectors and motor for discontinuity.This can be done by taking a resistance measurement between phases of the motor harness at the motor control mudule end.should be approx 32 ohms.You can also check at the motor,I have seen a few open circuit connections where the motor connections (spade clips) Push into the plastic motor housing,Hope this helps.
Sep 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fault 37 but pump is clear and does work part of cycle
there is a blocked pressure chamber or switch remove and clean then try again / it is letting to much water in
Jul 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,222 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
