Question about Brother HL 5250DN Laser Printer
Toner light after 1K pages
I bought my Brother HL-5250DN 6 weeks ago and have printed maybe 1000 pages. The toner light just went on and the printer no longer will print. The toner cartridge seems just fine and I can't override the error to get the machine to print. Any ideas?
Thanks!
  • 3 more comments
  • Anonymous Mar 06, 2008
    Right out of the box, the toner light is on and it won't print. Reloaded the drivers and put a brand new cartridge in - - still won't print. Arrrghhhh......
  • Anonymous Aug 08, 2008
    TONER BLIGHT WILL NOT GO OFF AND I CAN NOT PRINT
  • BOB5310 Aug 08, 2008
    TONER LIGHT WILL NOT GO OFF AND I CAN NOT PRINT
  • ebujak Aug 20, 2008
    This happens often and seems to be an issue that Brother should address.
  • Anonymous Mar 25, 2014
    I lost the key card for my new toner and can't get my printer to print. Is there an override?
On my unit, the toner light was lit steady amber and the Status light was steady red. I tore a small square out of a post it note, off the top (so that it had adhesive on it), and used that to cover the sensor path way found on either side of the toner cartridge. It is a clear plastic hole, centered toward the bottom of either side of the cartridge.
Posted on Aug 14, 2008
There's a reset flag that's set on the toner cartridge. Found out about it on oasis-imaging's refubishing pages: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
But my solution was to take the cartridge out, look inside the printer unit where the cartridge was and notice on the left hand side a small lever. Tape that down in the up position and continue printing.
It worked for me - I'd be interested to hear if it worked for you.
Posted on Mar 15, 2008
    Genius:
  • 3,587 Answers
I changed the Ink Cartridge a week ago but my printer is flashing the yellow toner button and will not print.
Take the toner cartridge out, give it a shake and put it back in.
How many pages did you print in the last week?
their "high yield" cartridge is only rated at 7000 pages so I am guessing the regular cartridge is rated around 3000 (or 6 reams)
It may also be complaining that the drum needs replacing depending on how long you've owned it.
Feb 24, 2011 | Brother HL 5250DN Laser Printer
I have a Brother 5240 printer. The toner light
Try this... it reads the level of the toner and can become faulty. This clears it.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jun 24, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Jun 05, 2010 | Brother HL 5250DN Laser Printer
Fuser Problem?? The ink does not cover the left side of the page
Pull out the toner/drum and on the backside there is a blueish/purple tab, it slides from side to side along a corona wire. Move the tab back and forth several times and then put the toner/drum back in and reprint.
Below are the instructions on how to accomplish this task.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000008/faq000208_018.html?reg=us&c=us&lang=en&prod=hl4070cdw_all
Apr 13, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
How to find number of pages printed from a brother HL 5250N
Turn on the printer.
Once it is on and the status light is on, press the Go button 6 time. Status light turns yellow and printer will print off internal configuration - including number of pages printed. Should be 3 pages. This report also includes the percentage used of toner, drum, laser, and fuser.
Dennis
Jan 27, 2010 | Brother HL 5250DN Laser Printer
Vertical black lines printing down page - changed toner without success
Hi Mike,
Check the drum. Take the drum and toner out of printer. Remove the toner and check the drum. Probably scratched.
S88
Dec 16, 2008 | Brother HL 5250DN Laser Printer
Only prints top of page
How does the test print page work? Does it still only print the top bit...
May 02, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
382 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
