Faulty drive motor
This problem just started. I have to spin the drive motor in my cd player to get it to work. The problem is increasing. It may or may not work. A simple problem that may make me have to buy a whole new cd player if it is not repaired.
  • fxbill Dec 20, 2008
    My motor slowly began to give me problems starting. Sometimes it will start and other times will simply shudder a little back and forth. Spinning by hand will usually get it going, but then the speed seems to be constantly changina little and it has trouble reading the CD....other times it works fine.
    Any advice is greatly appreciated....even a Southern Ca repair center would be nice although I am a tech and could replace a bad motor if that's all it is. I'm more concerned that it might be in the circuitry.
  • 1,512 Answers
You can replace the spindle motor to resolve the problem. It is quite a common fault. A quick fix that sometimes holds, is to remove 1 only of the 2 mounting screws from the top by coming in at an angle with a jeweler's screwdriver(if you are lucky the platter may have an access hole), and put a quick squirt of CRC 2-26 into the motor using the straw that fits to the cans nosel(if you don't have the straw, a syringe will do), enough to "flood" it, but not enough to get it everywhere. Then fire the unit up and put it in play mode-repeat track 1, this spins the cd at the highest speed and cleans the commutator and brushes enough to get the motor back to serviceability again. Removing the motor completely and running it on the bench using 6-12 volts for 10 mins and then reverse direction is even more effective. If you pull the spindle platter off the motor, be sure to measure with a steel ruler the deck height it sits at so as to reinstall it to the exact same height will also Good luck with your repair. A FixYa rating for this techo know how would be great thanks :)
regards
Graeme
Posted on Feb 16, 2008
Dvd player say no disc
Hi.
If this happens with every disk that means that either the drive unit is faulty or that there is a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If that does not work, then the drive is faulty. The most common fault is due to the laser beam not emitting on the proper frequency. The red laser light is not in the correct band and the drive does not detect that there is a disk inside.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens or laser problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens or the whole drive unit depending on the fault.
Regards.
Ginko
Jul 18, 2011 | LG Televison & Video
Tip
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
on Apr 21, 2009 | Philips Magnavox DVD/VCR Dual Player
My Craig ESP 60S Portable CD Player won't work. It starts spinning then stops. I have tried mode and program, but nothing helps. This is my second Craig CD player to do this.
sounds like it has a faulty laser and it wont read so the player stops the cd spin motor. try cleaning it and see if it works
Good Luck!
May 11, 2011 | Craig Personal CD Player
Yamaha dvr-s120 can not read dvd or cd. Drive is not spinning.
The CD motor could be faulty if you cannot hear any spinning noises from it from it loading or the lens could be faulty resulting in not enabling the dvd to register its prescence in the player to spin the disk.
Nov 04, 2009 | Yamaha DVR-S120 DVD Player
Cd drive does not spin after tray door closes
you may have a faulty spindle motor or a faulty/dirty laser unit which is not feeding information to the drive IC hence not spinning. hope this helps?
Sep 13, 2009 | Audio Players & Recorders
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
No cd player on my lap top
Sounds like the cd rom is faulty,the little motor that spins the disc could be faulty or voltage driving it is cut off due to a electrical component failure.You can open the unit and with the cd tray open look for a tiny microswith at the rear or font around the tray that activates power to the motor when the cd draw closes,it may be dirty but and need a bit of lubricant to free it up but most likely it's the motor.
Jun 25, 2009 | Compaq Evo N610C Notebook
Reads cd's but not dvd's
Feb 21, 2009 | Philips Magnavox MPD845
Can not recognise any dvd or cd
Oct 26, 2008 | Samsung DVD-P144 DVD Player
175 people viewed this question
 Grubhead
Grubhead
