Rf connector broke off tuner
Sansui 13" tv/vcr ac/dc model # COM311 ADB. The tuner has part # label that reads SAMSUNG TECC1040PG32E. I need a cross ref or where can i buy a tecc1040
Send tuner to "tni" for replacement ($30.00)
Posted on Feb 16, 2008
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Rf conector broke
You have two choices, you can: Take the set to a repair shop and have the tuner replaced. (expensive) Or you can use a VCR or other device with a tuner and fees video and sound in through the RCA jacks on the TV like you would to connect a video game console. Some shops that are worth a darn will actually repair the broken RF connector. You might ask the shop about what options they offer for that repair.
Apr 05, 2010 | Sanyo DS19310 19" TV
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
Is this set digital ready?
I'm sorry, but this tv is not digital. You might be able to use an inverter that converts 12volts DC to 120volts AC to power a digital converter box.
Nov 07, 2008 | Sansui COM312AD 13" TV/VCR Combo
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
your in luck the set can be repaired. a replacement F connector is available pt # 215543 from any RCA parts disributor. Have a tech help you with the replacement it can be tricky. in the mean time if you have a VCR use that with the compsite video hookup to the tv and let the VCR be your tuner.
Jan 16, 2008 | RCA F35317 35" TV
HOoking up DVD/VCR without correct connectors
either use an old vcr to act as a signal converter or go buy an "rf converter" from an electronics store to change composite audio/video signal to channels 3 or 4 and that should do the trick.
Dec 26, 2007 | Sansui COM311AD 13 in. Combo
"DEW" is on screen and VCR not working
When the DEW appears leave tv on for several hrs at room temp. The heat from the picture tube will help remove the moisture.
Jun 30, 2007 | Sansui COM311AD 13 in. Combo
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
