Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Mitsubishi WS-65313 - Will not turn on
I have a mits WS-65313, and the other day I went to turn it on and the green power light come on for about 2 secs. and then shut down. The tv itself will not come on. Took the back cover off and something near where the power cord comes into the tv set will click a few times when you turn the power on. Also if i unplug the unit and then plug it back in, the green power light will blink for a few secs.
  • 6 more comments
  • relo Feb 28, 2008
    The code my TV gives is two blinks pause one blink for five sets
  • oldcassava Mar 30, 2008
    When I turn My WS 65313 65in on he power light will keep on and no pictures. I had a repain man look at it and clean the board up it work for 10 minutes and shot off and has not come back on
  • LMOON Apr 06, 2008
    The front green light blinks constantly and the tv will not turn on either with remote or by the front button of the tv. The owner's guide talks about a timer and at one point the green light stopped and we were able to turn the tv on by remote, however, after about a week it started again and the green light will not stop even after unplugging the power and pushing the reset button.
  • Anonymous May 18, 2008
    The same. T.v woll not turn on just her some clicks in the back and the green light goes out
  • bhairless Aug 27, 2008
    I too have the same problem but worse! Today I push the power button on the tv and the blinking light remain blinking for 3hrs. I had left to run an errand I forgot I had push the power on. I reset the tv and then it went on. But, I do smell a burning smell. is there a code??????Please let me know bhairless@comcast.net
  • Anonymous Dec 09, 2008
    led light will not stop flashing.
  • timandpatty Apr 29, 2009
    My tv wont come on either the green light just keeps flashing, did any of you figure this problem out?
  • MATT BECKER May 11, 2010
    try pressing the MENU and DEVICE(or INPUT whatever the tv has) buttons on the front panel after the tv shutsdown and count the sequence of blinks. that is considered an error code.
  • 116 Answers
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
Mitsubishi WS-65713 Blinking green light. TV will not turn on!
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Dec 21, 2009 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
WS 65313 Mitsubishi went black all of a sudden
hold down the menu and input buttons after it shuts off it will flash with a code. call tv repair place and they can tell you what code means.
Jun 04, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
Nov 15, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Timer Light Blinking
Replace four caps in DM module 1000mf/25v 105 degree...
common repair for qualified Mits tech............T.
Oct 13, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
771 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
