Question about Acer Aspire 3680 Laptop
Acer laptop how to get the battery to last long?
I was wondering how u can get an acer laptop battery to last long mine last half hour that's it. don't know what up with that can the battery be defective how long should an laptop battery last?
  • 1,554 Answers
Batteries last about a year depending on if you let it fully discharge before recharge the very 1st time you use it.
the real average is to expect about 6 months usage before it degrades. by one year you'll be lucky if it gives you 30min charge.
Posted on Feb 15, 2008
Acer aspire 5750 black screen
My acer laptop 5750 went to blackscreen , even when turning off and on again, it kept black .
my solution is: Let your laptop on to drain your battery, once its drained, try turning on and feel if it doesn't have battery.
then charge your laptop for 4 hours, mine went back to work just fine
the display works fine 04/18/2014 good luck.
Aug 27, 2012 | Acer Computers & Internet
Hello i have an Acer Aspire One mini laptop. The battery does not work. It will not hold a charge
Hi you could try putting the battery in the freezer for a while about half hour or so sometimes it will reset the memory of the battery cheers tony
Sep 06, 2011 | Acer Aspire One PC Notebook
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
How many hours to charge a new acer 4738?, mine is too long to charge, is it natural if new?
A brand new battery has to be charged for 8 hours.For any battery related issue, a reset or calibration can be done.Just drain all the charge in the battery by using the laptop only on battery power( ie,with the Charger/Adaptor disconnected).After the comp shuts down due to no power,then charge the battery for 8-10 hours and then check if its fully getting charged or not
At times a BIOS update can fix battery related issues.
Oct 22, 2010 | Acer Aspire One PC Notebook
I want to buy a new rechargeable battery for my acer aspire 5100,5102WLMi. I have found a new battery that matches mine with all the specs. except the old one is rated at 4000mAh and the new one is rated...
no, you could use a battery with a higher amp hour rating.
It just a way of saying how long the battery will last at a certain amp drain. The higher the better
Sep 30, 2010 | Acer Aspire One PC Notebook
My Acer Laptop is about 3 yrs old and since the last month the battery has been running down within half an hour while in the past it used to last at least for three hours.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 25, 2010 | Acer Computers & Internet
I purchased an acer aspire one with qvc last year in dec the
Hello, Adonis.
Depending on its use, a battery lasting 2.5 hours after one year is not terrible. Over time, the battery loses power.
If the battery were totally dead in less that one year, I'd suggest contacting Acer, since it's still under warranty.
Hope this helps.
Oct 17, 2009 | Acer Computers & Internet
Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
ACPI 2.0 CPU power management standard: supports
Standby and Hibernation power-saving modes
71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
Acer QuicCharge™ technology
(for Aspire 5600 Series):
• 80% charge in 1 hour
• 2-hour rapid charge system-off
• 2.5-hour charge-in-use
90/65 W AC adapter
Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Battery back up is limited to 1 hour only
Did you do a full cycle charge when you got the Laptop? When you buy the Laptop you have to use the computer on battery till the battery dies and then charge battery for 12 hours and you repeat that another time. Most likely your battery it is damaged. Maybe you call the company and they might replace it for you.
Jan 16, 2008 | Acer Aspire 3680 Laptop
Battery problem
For acer 9410 you have 2 options for battery. an 8 cell battery which normally would last for 3.5 hrs. or a 6 cell battery that lasts for 2 hours. but that would depend on the application that you are using. for example, the battery will last longer if .you are just using it for email or chat compared to watching video. Why is that? its because watching video and playing games requires heavy processing thus consuming more battery. we should also remember that rechargeabu le batteries are consumable parts. it runs out in time. it is normal for it to degrade after a year. if it has'nt been a year since you purchased this computer then call acer and ask for a replacement battery. hope this helps?
Nov 28, 2007 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3680 Laptop Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
