I've used remanufactured cartridges for other brands of copiers, but the first time I've tried to use on the Canon MX700 it rejected and wouldn't print. Error message was u140. Cartridge was refilled by TrueStar from a Canon manufactured cartridge/tank.
Has anyone else been able to get MX700 to accept remanufactured cartridges?
-   same problem U150 with a genuine cannon Cyan cartridge - it worked intially and now won't do anything -   Guest
Jun 26, 2008
-   I am having the same problem, except I am using Canon ink...
-   Guest
Apr 24, 2008
-   Printer reads error code U150 and does not recognize the black ink tank. I have made sure that the tape is off and that the tank is installed properly. It lights up just like the others. As soon as you close the cover the alarm light comes on and it gives the error code.-   Guest
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
after refill canon 860 says ink is too low and does not print anything. how do i reset the printer...
(More)
after refill canon 860 says ink is too low and does not print anything. how do i reset the printer to accept refill ink? error message is "U410" with an "x" on the BK catridge icon on the printer.
setting up PIXMA 860 WITH NEW MacBook Pro,it has the new snow leopard. I keep getting printer off...
(More)
setting up PIXMA 860 WITH NEW MacBook Pro,it has the new snow leopard. I keep getting printer off line and 311 error code what is wrong?
Can't print from MAC OS X 10.5.8 to Canon MX700 network printer. Get error message pop-up box...
(More)
Can't print from MAC OS X 10.5.8 to Canon MX700 network printer. Get error message pop-up box ''Operation Could not be completed. client-error-not-possible'' What in the heck does this mean and what should I do!?
