Question about D-Link DHP-301 Transceiver
DHP 301 Hi When i try to run the DHP 301 configuration programme i get the following error message MACDISCOVER.EXE HAS STOPPED WORKING Followed by RUN TIME ERROR 62 INPUT PAST END OF FILE I have tried deleting and reinstalling the programme several times without success Any help would be appreciated
  • davidt2 Feb 16, 2008
    I have tried un installing the programme,re installed it using the latest version on the dlink website
    Have disabled firewall and removed anti virus software with the same result
    Genius:
  • 3,422 Answers
Error #62 Input Past End of File is a Program Exception Error and a Script runtime error. It means "A sequential file has been improperly created or edited and a line is missing" So it has something to do with an installed program.
The first thing i would like you to do is use Pcbug and Registry mechanic and scan ur pc to fix this error.If you still get the same problem then here are few options.
1. delete the Users.dat from within the program folder. if the file does not show up; go into your windows explorer options and choose to show all known file types and show hidden files. be sure to write down your character names by opening the Users.dat file with windows notepad.
2. the startup view file has been corrupted. by reading the program.ini file you can find out which View is the startup view. delete the offending file and restart the program. you will get Error 53 'file not found' the first time you start the program after deleting the file. the next time you start the program there will be no error message.
3. data file is corrupted probably do to a bad floppy disk.
4. error when loading/rescanning a large database. update the program.
5. in regional settings, check the language and the date/time.
6. this error may be a problem with the template files. the template files either have been corrupted or have coding errors within them. the files are not providing understandable code for the program. to correct this problem, you need to replace your template files.
7. no View handles. the maximum number of database View handles has been reached. increase the number Views=value in the database.
Finally i would say you can even go for a system restore to fix your problem.Go to Start>Accessories>sytem tools>System Restore
Goodluck..
Posted on Feb 16, 2008
  • Priya darshan Feb 16, 2008
    Microsoft has also recommended few steps to fix your problem Click HERE
    But i suggest you to do a system restore or restart ur pc and keep hitting f8 you then get a menu to Boot into "Last Known Configuration that Worked".
  • D-Link Master
  • 19,396 Answers
Hi Error #62 Input Past End of File is a Program Exception Error and a Script runtime error. It means "A sequential file has been improperly created or edited and a line is missing" So it has something to do with an installed program. A few options... 1. delete the Users.dat from within the program folder. if the file does not show up; go into your windows explorer options and choose to show all known file types and show hidden files. be sure to write down your character names by opening the Users.dat file with windows notepad. 2. the startup view file has been corrupted. by reading the program.ini file you can find out which View is the startup view. delete the offending file and restart the program. you will get Error 53 'file not found' the first time you start the program after deleting the file. the next time you start the program there will be no error message. 3. data file is corrupted probably do to a bad floppy disk. 4. error when loading/rescanning a large database. update the program. 5. in regional settings, check the language and the date/time. 6. this error may be a problem with the template files. the template files either have been corrupted or have coding errors within them. the files are not providing understandable code for the program. to correct this problem, you need to replace your template files. 7. no View handles. the maximum number of database View handles has been reached. increase the number Views=value in the database. If all this does not work, then you may need to re-install Windows as already suggested.
cheers
  • Ginko
    Ginko Feb 16, 2008
    LOL
  • 983 Answers
There is a problem with operating system just reinstall the operating system..
due to some virus attack some system files have became unstable & they are missing...
may be they are driver database files so you are getting this error so just reinstall the operating system and your problem will be solved...........
after reinstalling operating system i suggest you to install some good updated antivirus.....
    Brigadier General:
  • 3,614 Answers
Many errors surface soon after you install new hardware or software because conflicts often occur between the new product and previously installed components. To put an end to such messages, you might be able to uninstall the program or hardware (and hardware drivers) and then restart your computer to an errorless state.
If you do find that removing a new product eliminates errors, you might have to do some research to figure out the source of the conflict before you can reinstall the new product. Check the manufacturer's Web site for updated drivers, search support areas for known conflicts, and contact technical support for assistance. Sometimes tech support gurus can help you tweak a setting to end software conflicts.
Let it finish. Developing new computing habits can also limit the number of error messages you see. When you first start up your PC, let the hard drive come to a complete stop before starting a task; this lets your computer load all necessary drivers and operating system components necessary for efficient and error-free operation. The same concept works for your other programs. Let each program start up or shut down completely before you move on to another job.
Hi, i have a dell vostro 1520 laptop when loading up it has the windows xp screen then it goes to a blue screen with: STOP: c000021a {Fatal System Error} The windows logon process terminated...
This Solution is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown. Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence. uparrow.gifBack to the top CAUSE The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. Wh... loadTOCNode(1, 'cause'); The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
RESOLUTION To troubleshoot this problem, you must determine which of these processes faile... loadTOCNode(1, 'resolution'); To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration loadTOCNode(3, 'resolution'); If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Notes
  • Choosing the Last Known Good Configuration startup option provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. However, it does not solve problems that are caused by corrupted or missing drivers or files.
  • When you choose the Last Known Good Configuration option, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
Jan 18, 2011 | Dell Vostro 1510 Laptop Computer PC...
When i try to shut down my computer a blue screen appears with an error report : stop:c000021a {fatal system error}
This is the cause:
If possible contact a local technician to the do the below,if you are not sure of this process.
and also ask him to take a backup of your registry keys and create a system restore point without fail.
    Create crash dump
    Visual Notification
    • Winlogon.exe
    • Csrss.exe
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Dec 23, 2010 | Computers & Internet
Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Sep 04, 2010 | Sony VAIO VGN-CS118E/P NoteBook
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Ecspecialist filters\shooter.exe
Hi,  Please follow the steps:
Go to Start-->run, type..regedit Go to Edit-->find shooter.exe , press F3 until you find this entry named as "shell" c:\Program files\Ecspecialist...\shooter.exe right click-->delete
Feb 14, 2009 | Microsoft Windows XP Professional With...
Error Message at in mid startup, "0X10003A30" -" 0X01260624"
You could try to restore the system to the day before
or
You can use this app to uninstall your program completely even from the registry
http://www.glarysoft.com/download/ausetup.exe
I think the installation of the messenger stopped, you could use this app to rollback
http://wareseeker.com/freeware/ashampoo-magical-uninstall-2.82/215833/ashampoo_magical_uninstall282_fe.exe
Good Luck.
Live, Love, Laugh.
Jan 21, 2009 | Yahoo Messenger
When I click Microsoft LifeCam VX-1000 to run but window message error appear said "LIFEcAM.EXE HAS STOPPED WORKING" and the program will close. Thanks for your help.
hi,
if your running windows xp on your pc please try this
Clean boot procedure on Windows XP loadTOCNode(3, 'resolution'); To perform a clean boot procedure on Windows XP, follow these steps:
Warning You may temporarily lose functionality of some services when you follow these steps. When you restore the settings, the services are restored. However, when you restore the functionality, the original error message or behavior may return. Step 1: Start the System Configuration Utility loadTOCNode(4, 'resolution'); To start the System Configuration Utility in Windows XP, click Start, type msconfig in the Start box, and then press ENTER. Step 2: Turn off programs and services loadTOCNode(4, 'resolution'); To do this, follow these steps:
  1. On the General tab, click Selective Startup, and then click OK.
  2. Under Selective Startup, click to clear the following check boxes:
    • Process SYSTEM.INI File
    • Process WIN.INI File
    • Load Startup Items
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK, and then click Restart.
Dec 16, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
I have a Lexmark x5470 and evertime i start my computer now i get an error message which says im32fax.dil not found. How do i stop this from occuring.
Please follow the instructions below.
Click Start menu, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Load Startup Items check box.
3 When you are prompted, click Restart to restart the computer.
After restarting system.
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
Note: Doing this startup programmes will not run in the background however you can start the programmes later from start all programmes.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 05, 2008 | Computers & Internet
D-Link DHP-301 Transceiver Logo
755 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
